Carport Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-18-2008, 12:37 PM   #1
I am building a 24'x24' gabled roof carport on 6x6 wood posts. I am sandwiching the three 6x6 posts along sides with 2x12s - front to back. I am spanning the front 2 corner posts and middle with one 2x12 (no center post in front and middle). Any suggestion on splicing the 2x12...using a 16' and 8' long?
ront162 is offline   Reply With Quote
Old 03-18-2008, 04:27 PM   #2
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
It is all up to your local code. You must make sure that your spans are ok. If they are, I always notch the top of the 6x6's for the 2x12's to set in. I always like to break my 2x12 over top of one of the notches and make sure that I don't break both of them over the same 6x6.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 03-24-2008, 10:36 PM   #3
BuilderRemodeler
Checking Code Spans and talking with Mr. Inspector is a good thing prior to doing work.
Glue Lams and other framing materials are also available and at times are worth the extra investment if going end to end with a single beam is desired.
BuilderRemodeler
40 pages of useful Home Remodeling Charts, Home Addition Guidelines, Home Painting Tips, How to Determine a Deck Size and Build Your Deck Online! www.BrandsConstruction.com
www.HomePlansForFree.com One Story Ranch Detailed Free Home Plans
darylbrands is offline   Reply With Quote
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 01:47 PM
Which is better? (Non-vented roof construction with indoor pool) elbartee Roofing/Siding 21 03-26-2008 11:05 PM
conc slab inside/under a enclosed metal carport blthomas Building & Construction 3 02-01-2008 09:18 AM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 10:38 PM
Framing a carport on a detached garage nomagic Carpentry 3 05-04-2006 10:43 PM
