Carport - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 02:07 PM   #1
carport
hi, want to build a carport off the side of my house because I'm tired tired of clearing snow off my cars. My concern is that the front of the carport would be open at the northeast side of my house. So I would no doubt still get some snow on my cars during a 'Nor'easter'. Is there a way I can hang a tarp or build something that would temporarily cover the front of the carport? (I know, why not build a garage, too expensive plus I may have a variance issue). Or is there some kind of a kit that I can purchase that would allow for an automatic temporary door (cover). I don't want to go through the process of building a carport if i still have to clear snow off the cars.
reekeyg is offline   Reply With Quote
Old 03-01-2011, 04:31 PM   #2
Rewards Points: 5,336
I wouldn't buy any materials until you get the regulations from the building dept about carports. You might come up with the same restrictions.
If there are similiar properties with garages in your area, the variance issue might not be that much of an issue.
Carports, in my mind, are for warmer climates.
Ron
Old 03-01-2011, 05:46 PM   #3
waterman1971's Avatar
Rewards Points: 150
Maybe a mansard across the front would help with driven snow.
waterman1971 is offline   Reply With Quote
Old 03-02-2011, 06:18 AM   #4
thanks
Converting carport into a room troybliss Remodeling 8 08-14-2009 11:43 PM
Converting Carport to a living space budlover Building & Construction 1 06-06-2008 09:30 PM
Carport to Garage: Fire barrier question Grommet Remodeling 2 03-28-2008 05:18 PM
conc slab inside/under a enclosed metal carport blthomas Building & Construction 3 02-01-2008 10:18 AM
Framing a carport on a detached garage nomagic Carpentry 3 05-04-2006 11:43 PM
