Care For A Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2007, 07:30 PM   #1
Care for a crawl space
how do i care for a crawl space.
and keep mushrooms from growing on the dirt?
thanks
bobbyfrommaine is offline   Reply With Quote
Old 08-07-2007, 08:07 PM   #2
Eibwen
Check for sanding on the area under the house and then a vapor barrier. Good ventilation is a must. Check with a local termite company for some suggestions.
Sammy is offline   Reply With Quote
Old 08-09-2007, 10:20 PM   #3
Rewards Points: 5,336
Definitely a clear heavy guage(4-6mil)plastic sheeting to cover the ground and to go up the walls. Mine goes up to and is attached to the sill plate. Ventilation can't hurt.
Ron
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Crawl Space care...??? bobbyfrommaine General DIY Discussions 1 07-25-2007 08:37 PM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 08:26 PM
Crawl Space needs "re-insulating" bigNY Building & Construction 1 10-12-2006 01:55 PM
