Cardboard Concrete Tubes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-03-2009, 02:34 PM   #1
cardboard concrete tubes
I'm about to build a deck and my question is do I have to use cardboard concrete tubes ( sonotubes ) or could I just use PVC plastic tubes to pour the footings? where I work I can get 10-12 inch pvc plastic pipe for free, and if I can avoid paying $9 a tube ( also have several future projects that I will need footings for) that would be a good thing. And if I can't used PVC, could someone please tell me why? I'm one of those that has to know the reason behind everything. : )
I've searched the site and couldn't find this covered anywhere else, but if it is, a link to that forum would be appreciated too. Thanks
mike6x7 is offline   Reply With Quote
Old 10-03-2009, 02:51 PM   #2
BIGRED
Rewards Points: 252
A 10-12" diameter footing will slowly sink over several years unless you are building on rock in which case you wouldn't need footings. I don't know the formula for figuring pad area under the leg to support a certain load range, but I have a 40' x 8-12' deck that I have to tear down because I put in 12" round x 4' deep footings back in 1986 and it is looking like the floor of a carnival funhouse just because I didn't want to put out for 2-3' sono tubes. Will I ever learn???
Grampa Bud is offline   Reply With Quote
Old 10-03-2009, 03:31 PM   #3
Registered User
Rewards Points: 5,212
I think they would work. Dig below frost line for your area, pour a squarish flared foot on gravel with a re-bar sticking up for the later pour in the tube and attachment bracket for post. Sizing piers, and frost proofing footings: http://books.google.com/books?id=1gg...num=3#PPA31,M1
Gravel for frost: http://rockproducts.com/mag/rock_agg...prevent_frost/
Foam protect piers: http://www.oikos.com/esb/43/foundations.html
2006 deck code, footings, beams, joists, ledgers: http://www.awc.org/Publications/DCA/DCA6/DCA6.pdf
Be safe, Gary
Old 10-03-2009, 05:14 PM   #4
Civil Engineer
Rewards Points: 4,566
The main purpose of a sonotube is to make it convenient to place concrete. The cardboard adds no strength to the concrete, and if the cardboard is not stripped off the concrete, it eventually rots anyway. Absolutely no reason not to use a PVC tube, unless you dislike the appearance of PVC pipe and you plan to leave part of it exposed above grade.
By the way, check previous posts regarding the need for standoffs (column supports) to keep your wooden column posts from directly contacting concrete. Simpson makes a line of them, other companies do as well.
Grampa, if you put in 4 foot deep, 12 inch diameter footings and they are sinking, you must be in some of the worst soil on earth. Very unusual in my experience. In most locations, you can use an 8 inch diameter tube, however you need to check with the local building inspector, and of course the required diameter depends on local soil conditions. If you are building over fill, you need a thorough soil investigation before you can size the footers, but for normal soil, there is a presumptive allowable bearing pressure in the code books.
Old 10-03-2009, 06:24 PM   #5
Old School
Willie T's Avatar
You sure you typed that like you meant it to read?
You feel the trouble is due to you putting in piers a foot deeper than what you suggested? Perhaps your foundation heaved upward to give you that roller-coaster look instead?
And could you run the size of that deck by us one more time? I can't visualize it.
Willie T
Old 10-03-2009, 07:20 PM   #6
No - I think he is saying he needed 2-3' WIDE sono tube for his soil
I think it depends upon your soil conditions for width
We have very rocky soil & digging I hit ledge @ around 42"
Old 10-03-2009, 08:12 PM   #7
Old School
Willie T's Avatar
Ok.... 27" diameter tubes? Or 24" to 36" maybe. I see now.
Willie T
Old 10-03-2009, 08:34 PM   #8
Remodeling Specialist
Since you have them for free use them on a 20" footing base,
The standard for a column is a footer minimum of 20" and at least a 10" tube and I always throw re-bar in mine.(I've used 8" tubes on small decks if they are reinforced with rebar bent into the footing)
Do not expect a sono tube or 12" column to work without a footing under it. Footings can be poured in a prepared hole, at the width desired by flaring out the bottom with your shovel and post hole digger and the tube added after 10-12" concrete is poured. Drop in the form (PVC or sono and back fill plumb ending them above ground.
Baron is offline   Reply With Quote
Old 10-03-2009, 10:22 PM   #9
Thanks everyone. Yes, I planned on placing the columns on poured footings, but I just wasn't sure about the tubes. I planned on using a cut-off wheel to cut the upper 3 or so inches off the PVC after the concrete has cured. Thanks again.
Old 10-04-2009, 12:51 AM   #10
morningwood
Where Im from, most our decks we use 8" piles, however we go a minimum 8' deep.
I believe it is the depth that helps stop heaving. Need to get way below the frost line. Perhaps you dont have a frost line where your from
rahfiki is offline   Reply With Quote
Old 10-04-2009, 04:19 AM   #11
Rewards Points: 582
I've never seen Sonotubes used in the UK. What is their advantage compared to just digging out the hole and concreting it? Do they just save a bit of concrete?
stuart45 is offline   Reply With Quote
Old 10-04-2009, 07:28 AM   #12
Rewards Points: 4,534
IF you can dig a smooth-wall's hole, don't worry about it,,, rarely do we see that here because of clay in the soil,,, frost can & will ' lift ' supporting columns as it's molded to the conc column
Old 10-04-2009, 09:18 AM   #13
Rewards Points: 582
Thanks IRC, I can see what you mean. we do have clay soil and frost heave around here, so these could be usefull. A bit of advanced American technology to talk about over a pint down the pub tonight.
Old 10-04-2009, 12:03 PM   #14
Concrete & Masonry
Rewards Points: 526
I agree completly with Daniels info, but would add in what IRC said. In our region, this is ths simplest, effective way to install deck footers.
If your seeing large settlement in 12" piers in OUR soils, here's a few scenarios I would look into:
- Where the holes tapered or rough (no tube used) & heaved due to frost. Often times when a tube heaves, ground can fall in at the bottom, not allowing the tube to return back down when the frost recedes.
- The tubes where poured on backfill or loose fill.
- All undisturbed soil wasn't removed after a power auger drilled the holes and/or the bottom of the hole wasn't tamped.
jomama45 is offline   Reply With Quote
Old 10-04-2009, 08:12 PM   #15
Rewards Points: 1,910
Mike, cutting off that 3" of PVC after the pour sounds like it would be more trouble than it's worth. How about use your PVC but leave each one 3" short. Buy one sonotube (they are actually pretty cheap) and cut it into 3" bands. Duct tape the 3" band to the top of your PVC. The day after the pur you'll be able to easily remove the 3" sonotube section.
The duct tape will hold that section in place with no trouble as their is very little pressure on the top 3" of the pour. I had to extend a 16" diameter sonotube another 5" this way and it held together just fine.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
concrete sono tubes, spans, etc chickaloon Building & Construction 18 06-28-2011 10:24 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
