Capping For Windows - Purpose? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2008, 11:54 AM   #1
Power Gen/RS Engineer
Rewards Points: 566
Capping for Windows - Purpose?
I am just curious. Is aluminum capping for windows just to protect the wood beneath? It seems like the flashing system is designed to keep moisture out of the opening/building interior and is separate from the cap. That is, you will always have (or should always have) flashing but may or may not need to cap, is that correct?
In lieu of the aluminum capping, I have also seem people simply paint the wood. Assuming that the appropriate paint is used, I would imagine that this will protect the wood as well. However, the aluminum would seem to be more maintenance free.
Am I warm here?
Thanks and Happy New Year,
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 01-01-2008, 01:02 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,648
I'm afraid you've got me Totally Confused.........
What Exactly are you calling a "Window Cap",..??..??....
Bondo is online now   Reply With Quote
Old 01-01-2008, 01:44 PM   #3
Rewards Points: 566
Sorry for any confusion. Around here at least (Chicago, IL), they will cut/bend aluminum to cover the decorative wood framing surrounding the exterior of the window. Two residential GC's that I know referred to this as "capping" the window (ufortunately, I lost both of their numbers when I lost my last cellular phone!).
Old 01-01-2008, 06:06 PM   #4
I think most people have the wood capped just to cut down on maintenance. You are talking about having all four sides capped and not just the drip cap on top, right?
Drip cap
jerryh3 is offline   Reply With Quote
Old 01-01-2008, 06:38 PM   #5
Rewards Points: 566
Drip cap
Yes, that is correct. They usually start at the bottom, then do the vertical sides and finish with the head, overlapping each as they go.
So this is primarily for maintenance?
Thanks!
Jimmy
Old 01-01-2008, 10:10 PM   #6
remodeling pro
Thanks!
Jimmy
Usually to eliminate having to paint the window trim. Unfortunatley , on old work,it is all too often used to hide rotten wood without addressing the source of the rot; out of sight, out of mind I guess, at least for a couple of years. The other problem is that very few siding installers know how, or will take the time to properly fold up the metal flanges necessary for water waterproofing the metal, preferring to rely instead on a bead of caulking over the joint. The caulking fails within a year and the rot begins undetected behind the metal.
troubleseeker is offline   Reply With Quote
Old 01-03-2008, 10:40 AM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Aluminum capping is most often used to cover up where the outside stops were chopped out during the installation of a replacement window. As mentioned, it also makes the installation maintenance free. It is common to install the aluminum over wood trim that is in less than ideal condition. Some people have concerns about this, however the fact is if the capping is done properly and a high quality caulk is used, it will be sealed in for years to come. In addition, the brickmold(wood trim) is there merely for aesthetic purposes and has nothing to do with the structural integrity of the new window. I often have customers who are very concerned with the condition of the brickmold and want it replaced, however when I explain that they would be spending money to replace something that is "decorative" in function, yet will no longer be seen behind the capping, they usually reconsider. Sometimes though, they insist so I go ahead and fufill their wishes for a small fee.
HomeSealed is offline   Reply With Quote
Purpose of square black washer on outlet cover screws? darsunt Electrical 3 07-20-2007 10:27 PM
