Cape Cod Attic Bedroom Insulation On A Budget - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 05:35 AM   #1
Lightbulb
Cape Cod Attic Bedroom Insulation on a Budget
Hi Everyone,
I just purchased a 1500 sq. ft. 1936 Brick Cape Cod in Arlington VA. Very hot summer + cold Winter. The attic bedroom stayed warm enough during the winter but now that the weather is changing it is unbearably hot.
I am looking at ripping down all the fiberboard and insulating the whole roof and walls but stumped on how to get the most bank for my few bucks.
Problem 1. Low Budget.
Problem 2. Only 5.5 inches of space from roof deck to end of rafter, not allowing much space for insulation.
I wish I could afford closed cell spray foam but it sounds extremely expensive.
What I was thinking was starting fresh and..
1 wrap the whole roof deck in thin reflective foil radiant barrier. Radiant side facing roof.
2. Squeeze in some eco friendly R13 thats up against the non radiant side of the barrier leaving hopefully a 1 inch gap to end of rafter.
3. install 1-2 inch thick rigid foam boards over top that with 1 sided radiant barrier facing the roof and hopefully having that inch of airspace.
4. Drywall right onto the foam board (non radiant side).
Any professionals or DIY's with info/suggestion or advice from problems with what I am proposing.
Thanks in advance!
justsayben is offline   Reply With Quote
Tags
attic bedroom , fiberglass , insulation , radiant barrier , ridgid foam board
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 09:49 PM
Any ill-effect on the house if without attic insulation? htabbas Insulation 12 01-02-2012 10:30 PM
Insulation in the attic when the furnace is up there Jimmybrp Insulation 2 12-11-2011 03:26 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 03:10 PM
Attic Foam Board Insulation JasonCA Roofing/Siding 3 10-07-2010 01:56 AM
