Capacity Of 2x4 Walls For New Roof Attic Trusses - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-13-2010, 10:47 AM   #1
capacity of 2x4 walls for new roof attic trusses
My bungalow is 36ft x 32ft with the standard Howe trusses spanning the 36ft side. I would like to swap out the Howe trusses for some attic trusses which would give me a 2nd storey living area. Seeing that the house was built in the 60's, the walls are 2x4, 16'' oc. My question is, what are the chances that the 2x4 walls will be strong enough to take the new loading of heavier trusses, higher roof and additonal 2nd storey loading. Standard 8ft ceiling. Snow loading in my region is 60lbs/sq.ft.
I guess the obvious choice will be to have a structural firm confirm this, but if anyone has experience, your input is much appreciated.
Soccerfan8 is offline   Reply With Quote
Old 12-13-2010, 10:58 AM   #2
kwikfishron's Avatar
Rewards Points: 824
Welcome to the forum.
You just answered your own question.
kwikfishron is offline   Reply With Quote
Old 12-13-2010, 12:32 PM   #3
Adding a 2nd floor you have to worry about the foundation load too
Old 12-13-2010, 01:45 PM   #4
Registered User
Rewards Points: 526
The foundation may not be a problem but the studs will because of the roof span. Check with your local B.D.
Changing to attic trusses may not require many changes as that may still be considered an attic, not a new second story. http://docs.google.com/viewer?a=v&q=cache:EJENK_uA9RQJ:www.cr-ar.com/pdfs/Building%2520Code%2520Changes.pdf+R602.3(1)+2006&h l=en&gl=us&pid=bl&srcid=ADGEESh311Kosslp7jsjp9WhUX xZsgSiyNaWb-eW0YminVwmPUavLlW75BKLoV9em4LFCAydmTGQlkUFOPm8AqHk RP5wLQGQQGkwyzAGtlN4D2DqCiCLwprOpEbvvjeGk6CEhyHiVd tK&sig=AHIEtbRa4Ah_IICPQ3BR1txlzU01V4JQIg
2x4 at 24”o.c. will support a habitable attic up to 32’ span, Table R602.3(5), footnote9c0: http://publicecodes.citation.com/ico...002_par005.htm
The existing foundation may already be strong enough to handle an additional story (if labeled as such); it depends on the load bearing value of the soil: http://publicecodes.citation.com/ico...9_4_sec003.htm
Gary
Old 12-13-2010, 03:51 PM   #5
Framing Contractor
You don't need an engineer, architect or anyone else to tell you if 2x4 walls can handle this. 2x4 walls go 2-3-4 stories. Doesn't matter what truss you use unless for some reason they tell you you need a 2x6 wall. Millions and millions on houses are built with 2x4 walls.
However, you do need an architect or engineer to do what you want to do. The 2x4 walls will never be an issue as far as handling 2nd story and any truss as far as I know.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-13-2010, 03:57 PM   #6
Framing Contractor
Not in NJ. It must be a Regional thing because a foundation fpr a two story and one story are built the same. There are never any issues with a foundation for a one story house putting on a 2nd story.
Joe Carola
Old 12-13-2010, 05:09 PM   #7
Where I live a 2 story house foundation is different than a single story.
warnerww is offline   Reply With Quote
Attic fan options P550 Roofing/Siding 1 08-22-2010 12:47 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Straighten Roof Trusses A.Gilbert General DIY Discussions 4 04-06-2010 07:24 AM
Pole barn no walls just roof 24X36 nrgeek Building & Construction 12 02-25-2009 12:15 PM
Attic trusses and proper roof pitch Rob63 Carpentry 1 07-28-2008 03:38 AM
