Cantilever Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 12:33 PM   #1
cantilever joist
how far out can i cantliever my second story add. can i hang 2 feet using 2x10x8s is 6 feet sistered with exsting joist enough .
tootsie007 is offline   Reply With Quote
Old 01-16-2011, 01:14 PM   #2
cantilevers can't go out any more than 1/3 of the length of the supported sect., so yes, you can do it but nail those sisters real good. Also keep the new joists on layout directly over the supporting wall studs. Cantilever joists should be installed w/ the crown down. whether 2x10's are good enough depends on how much wieght you're putting out there. If you're using cement siding or terracotta roofing, consider an upgrade
Dwoodsmith is offline   Reply With Quote
The Following User Says Thank You to Dwoodsmith For This Useful Post:
tootsie007 (01-16-2011)
cantilever joist giglotti007 Building & Construction 3 12-04-2010 10:29 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 08:10 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 08:15 PM
