Old 01-19-2010, 12:49 PM   #1
Can't open Milgard Aluminum Single hung windows
I have 10yr old Anodized Single Hung Milgard windows. They have a latch handle on top of the lower window that has Milgard stamped on it. What is happening is that when I try to open the windows it seems that the top seal on the lower window catches on the upper fixed window catch that the lower window latch hooks onto to lock the window. Once I lift up hard enough the lower window seal will go past the upper window catch area, then the window will go up and down easly. All of the windows do the same thing. So I think it's either the seal has hardened up or expanded. There are no signs of corrison where the seal is located. Any thoughts?
riverjamie is offline   Reply With Quote
Old 01-19-2010, 03:39 PM   #2
General Contractor
Never seen that problem before, I would call milgard and ask them.
KennMacMoragh is offline   Reply With Quote
Old 01-19-2010, 06:15 PM   #3
Thank you for replying. Already contacted Milgard. I don't have the model number for the windows. They did provide the instructions for removal of the sash. So maybe after I remove one of the sash's I might be able to see what is going on better. Maybe there's a nylon guide that maybe worn?
Replacing aluminum windows installed in 1992 cocean Carpentry 12 09-01-2009 11:24 AM
Why is my aluminum wrap around my windows pulling away? Kl483@yahoo.com General Discussion 5 04-21-2009 06:04 AM
Removing sliding pane from Milgard Aluminum rocketdoctor Building & Construction 2 04-14-2009 08:44 PM
Double Hung wooden windows with metal runners Hisgirl Remodeling 4 01-02-2009 10:17 PM
Thermal Barrier Windows vs Vinal Windows MeraleeCrowl Remodeling 6 11-05-2008 05:46 PM
