Can't Get Through Super Tile! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-30-2006, 12:13 AM   #1
yoe
Rewards Points: 16
Unhappy
Can't get through Super Tile!
I've been trying to hang these nice shelves in my bathroom,
I have never drilled into tile before, and when I asked, the guy in the hardwood store said I needed a special drill bit.
so I bought it, this drill bit was very small (much smaller than the screw that was to go in after it) but it had this diamond shaped head, so I went with it. Put some masking tape on the tile to avoid cracks, and started drilling, it seemed to be working ok, but after about 0.5mm it I couldn't go further. So I went back and bought another drill bit, this time bigger, badder, designed for cemant or concrete, and started drilling with that. the whole widend, got another 0.5mm in, and thats it!
I feel like I'm trying to drill into superman!
Nothing will budge. When I try harder, I just get smoke.
I'm using a BOSCH 5.5 Amps drill.
what am I doing wrong?
I know these ceramics could be drilled through cause there is already a very nice hole there that the former resident drilled.
help?
yoe is offline   Reply With Quote
Old 07-30-2006, 07:47 AM   #2
They're all fixer-uppers
J187's Avatar
Rewards Points: 514
Is the bit you got a carbide tipped masonry bit? That's the one that'll do it. You may need to exert a little force at first, but make sure you hold up on the pressure once you know you nearing the end.
J187 is offline   Reply With Quote
Old 07-30-2006, 01:19 PM   #3
Do you have a hammer drill?
Sportbilly is offline   Reply With Quote
Old 07-30-2006, 01:26 PM   #4
yoe
Rewards Points: 16
Nope, I do not!
What does it do? and how does it look like?
Sounds Dangerous to me, drilling with a hammer drill on a ceramic tile
Old 07-30-2006, 07:53 PM   #5
Does just like it sounds, drills, with a slight hammering motion, ask at a tool store. Ask for a masonry bit too, in case that's not what you got the second time around
I've used them on ceramic before with no problems, just make sure the tiles are bonded to a reatively solid surface, any more tips from a pro?
Old 07-30-2006, 08:03 PM   #6
carbide tip
redline is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 07:15 AM
Tile roof questions/repairs help please xoroniox Roofing/Siding 3 12-17-2006 02:02 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
