Can't Find Studs In Old Apt Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-02-2013, 11:03 AM   #1
Can't find studs in old apt wall
I live in a 1920s apartment building. I'm opening up a wall to try to install a pocket door. I expected to find studs but instead am just finding tons of mortar. It makes demo a messy business. I'm wondering if I'm missing the studs or if it was standard back then to create walls out of mortar, then plaster over them. Here's a pic.
scott490 is offline   Reply With Quote
Old 04-02-2013, 11:26 AM   #2
Rewards Points: 626
you live in a apartment? and your land lord is letting you do this?
Nailbags is offline   Reply With Quote
Old 04-02-2013, 11:52 AM   #3
Roofmaster
Rewards Points: 2,172
Fire rated construction, no wood studs. You have bitten off as they say, more than you can chew.
Old 04-02-2013, 12:59 PM   #4
Why is that?
Old 04-02-2013, 01:00 PM   #5
It's a co-op and I'm the owner
Old 04-02-2013, 01:52 PM   #6
Roofmaster
Well thats true. You may be very talented and be able to do anything. I guess I assumed that you would know what you were working with as soon as you saw what the wall was made of.
Old 04-02-2013, 04:18 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,996
Most applications require gluing a wood buck frame to the concrete mortar and setting the door in that to attach to.
You, in theory, could also you tapcon or concrete screws and set the door that way.
Old 04-02-2013, 04:40 PM   #8
Nope. This is my first foray into my walls. I always assumed they were lath and plaster, being built in the 20s, but I was wrong. This is all mortar.
Old 04-02-2013, 04:54 PM   #9
Roofmaster
We used to refer the steel frame of a metal door to be mounted in masonry as a buck. If wood is used we referred to the frame as its jambs.
Old 04-02-2013, 09:30 PM   #10
I read a little about building pocket doors recently. It's difficult even for the experienced. Experienced contractors get the framers to install them, or something like that...I just remember installers hate them and special procedures are used by those with enough experience to know they're needed. You may want to quit while it's not too late, unless you've done it before.
Dorado is offline   Reply With Quote
Jacking Exterior Wall / Replacing Sill Plate Pittsville Building & Construction 2 06-16-2012 09:11 AM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 01:32 AM
how do you find the wall studs? cbzdel Building & Construction 1 07-01-2011 01:10 AM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 09:41 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
