Can't Figure Out Basement Drain?? HELP - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-28-2009, 10:26 PM   #1
Can't figure out basement drain?? HELP
OK. I bought a house a year ago that is now 4 years old. In my basement the perimeter is cut out about 4 inches deep and 3 inches wide. The perimeter is covered in concerte. I have a sump pump pit but a sump pump was never installed. The sump pump pit has spots for three pipes to come through the ground and into the pit put they were never cut out. My pit is filling with water. After getting all the water out of the pit it just fills up again. The water seems to be coming from the bottom of the pit where a few holes were made. I also have water in the perimeter as well. My questions is what is going on. I have read all about basement perimeter drains and it seems that the drains should have a pipe that runs the water into the sump pit. But my sump pit is solid with the exception of the few holes at the base. Can someone please explain what is going on. I plan on having a sump pump installed in the morning. Once the water stops filling the sump pit will the water in the perimeter go away?? Thanks for your help.
edbusjr is offline   Reply With Quote
Old 12-29-2009, 07:25 AM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 6,482
You have what is called a "French Drain". Get a sump in it, and it will do the work that it was designed to do (sump well).
Basement floor drain causing me anxiety tondar Plumbing 1 06-21-2009 08:06 AM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
Basement floor drain back-up luv2plumb Plumbing 3 06-09-2008 10:26 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
adding a basement tub drain wibass Plumbing 2 06-09-2007 06:50 AM
