Canned Foam Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2011, 08:18 AM   #1
I hope this is the right place to ask this question.
I have a fireplace. Not brick just sorta like an insert. Condo built around 1985 Maine coast. It was inefficient so I had a Jotul Gas Stove installed. The little thing puts out heat nicely. The company stuffed fiberglass insulation into the fire box of the fireplace and put a black tin cover over the opening. The fireplace is trimmed with regular wood door moulding.
My problem is that I don't think they closed the damper before they stuffed that insulation in there. There is a wicked draft all around that tin (sheet metal I guess you would call it) insert.
Should I use black caulk around
it or can I use that spray foam insulation. The stove is a B-vent stove. The stove is about 2 inches from the insert.
Is that spray foam insulation safe in such a hot area. What about caulking? I don't want a fire.
Can I paint the spray foam once it's dry?
WindingRoad is offline   Reply With Quote
Old 01-01-2011, 10:07 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Most of the foam in a can products are not meant to be used in high heat applications. You might be able to find a suitible product at a fireplace type specialty dealer
to answer your other question, cured foam can be painted
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 01-01-2011, 10:15 AM   #3
What about regular caulking like that used for windows etc?
Old 01-01-2011, 10:23 AM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Companies like Rutland and Red Devil both make high heat rated products that are typically sold under names like "fireplace caulk". you can probably find it at farm and fleet type stores, hardware stores, and even lowes and depot
Old 01-01-2011, 07:38 PM   #5
Thanks I didn't know about fireplace caulk. I appreciate your time in answering.
Old 01-02-2011, 09:08 AM   #6
Rewards Points: 5,336
I would call back the installation company and have them remedy the issue.
It would help if you knew the exact issue. Speaking to contractors with some understanding of the correct way of installing this unit is better them vague generalizations which can be explained away.
Do you have the installation instructions for this unit?
If not, get them off the internet and check what they did.
Ron
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Is spray foam insulation that much better than fiberglass? HautingLu General DIY Discussions 18 09-21-2010 06:36 PM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 08:18 AM
