CanLites Needed In Insulation Addition? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-12-2007, 05:28 PM   #1
CanLites needed in Insulation addition?
I am being told by a contractor that Canlites are not needed for an add on blown in insulation using Knauf Jet Stream® 73.3 Blowing Insulation.
Another contractor who was going to use Insulsafe SP from CertainTeed was planning on using Canlites.
Can someone help me with which if any is better and any pros and cons
Thanks, I appreciate any input
i009981 is offline   Reply With Quote
Old 12-12-2007, 05:47 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
huh?
- Build Well -
Old 12-12-2007, 05:51 PM   #3
CanLites are enclosures put around existing light fixtures prior to blowing insulation into the attic
Old 12-13-2007, 01:12 AM   #4
Home Renovations GC
kiwi54's Avatar
.......you may have misunderstood your contractor. Recessed lighting is commonly can lighting, if you're installing recessed lighting with insulation then you need an insulation approved can light, usually installed with a lower watt bulb.
If you're installing under-ceiling lighting then you do not require a can light BUT you will require a recessed lighting outlet to house your wiring and hang the fixture from.
Hope that helps...))
kiwi54 is offline   Reply With Quote
Old 12-13-2007, 10:26 PM   #5
Union Electrician
goose134's Avatar
There are also IC rated can lights. The housing provides the three inches of space around the fixture. You can bury them in insulation. They cost a bit more, but they install in one shot as a contained product, rather than fiddling around with whatever you are talking about.
goose134 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Insulation under kitchen addition rubicon789 Carpentry 11 01-26-2007 04:24 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
