Can You Use "safe And Sound" As Thermal Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-14-2010, 09:35 PM   #1
Can you use "safe and sound" as thermal insulation
Can you use "safe and sound" as thermal insulation. I have a bunch remaining and I need to insulate a small roof. Can I use the safe and sound? If so, what's it's R value?
Thanks,
Zantar.
zantar is offline   Reply With Quote
Old 02-15-2010, 07:13 AM   #2
ccarlisle's Avatar
Can you? Sure, no law against it...but compared to what? not using it and leaving it lying around doing nothing? If so, use it...
But if you're just using it for its R value compared to some other kind of insulation, you could do better. But, it's better than nothing.
Go to roxul.com to find out more.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 02-15-2010, 11:00 AM   #3
Rewards Points: 582
Sound insulation is different to thermal, although it will help a bit. Try and swap with someone for thermal insulation, you may as well do a proper job if possible.
stuart45 is offline   Reply With Quote
Old 02-21-2010, 09:16 PM   #4
Okay. Thanks guys. Just thought I'd check as I could not see the R value spec on Roxul's webpage. Anyway, I'll just go out and grab some insulation batts then.
