Old 11-06-2011, 03:43 PM   #1
Can you cut a 55 gallon drum with a jigsaw?
I want to make a woodburner out of a 55 gallon drum. They sell kits, but the kit needs several rounded holes cut, so I can use a diamond bladed circular saw like I wanted.
Will a jigsaw work? Everyone said my last wood burner was a huge fire hazard, trying to get something decent in before winter.
tibberous is offline   Reply With Quote
Old 11-06-2011, 04:37 PM   #2
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
Yes you can use a jig-saw to cut metal. I did it all the time when working sheet metal.
You need to get the right blades though, wood blades from the depot will not do it.
By the way, I hope you were not serious about using a diamond blade on steel.
Andy.
AndyGump is offline   Reply With Quote
Old 11-06-2011, 04:46 PM   #3
Andy.
Yeah - aren't you supposed to? That's what I normally use to cut steel, it works perfect. I've used it to cut brick / concrete too - I think that is actually what it's made for.
Old 11-06-2011, 04:50 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
a 55 gallon drum is made of pretty heavy gauge metal... not sure how well a jigsaw blade would hold up.. why not use a mini grinder
woodworkbykirk is offline   Reply With Quote
Old 11-06-2011, 05:19 PM   #5
JOATMON
ddawg16's Avatar
Good excuse to go out and buy that Sawzall you wanted. I didn't realize how useful it was until I got one....works great for cutting limbs on trees as well.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 11-06-2011, 05:47 PM   #6
joed's Avatar
Jig saws will cut a barrel. I have done it in the past.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-06-2011, 06:07 PM   #7
Before you go cutting into that drum you should make sure that what was in it wasn't flammable.
rustyjames is offline   Reply With Quote
The Following User Says Thank You to rustyjames For This Useful Post:
VIPlumber (11-06-2011)
Old 11-07-2011, 12:50 AM   #8
Danieldot
yes you can use jigsaw to cut the drum, all u wanted to do is use coolant to get a perfect finishing.
danieldot is offline   Reply With Quote
Old 11-07-2011, 07:21 AM   #9
Developer by Day
Send a message via AIM to KevinACrider
Nobody realizes how useful a Sawzall is until they buy one. I picked mine up 3 years ago and cannot count the uses I have found for it.
KevinACrider is offline   Reply With Quote
Old 11-07-2011, 07:48 AM   #10
gravity always wins
Use a fine toothed metal cutting blade in your jigsaw and it will work fine. Sawzall blades are usually too broad to make tight turns. Go slow and expect to break a couple of blades. Drill a starter hole for the jigsaw blade to start.
Dewalt 18V Jigsaw Proby Tools 4 07-30-2010 12:20 AM
Bayer liquid weed killer & 2 Gallon flomaster pressure sprayer combo pack @ HD $10 whataboutj Landscaping & Lawn Care 25 05-13-2010 11:01 PM
Drum trap, best to replace them? diymonkey Plumbing 4 06-04-2009 09:14 AM
What are you paying for a gallon of paint? Git Painting 8 09-23-2008 11:59 PM
Is a 40 Gallon water heater electric enough for a 1 bath house (2 people). twilightcall Plumbing 6 08-06-2008 10:11 AM
