Can Warped Studs Be Fixed Or Replaced - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-15-2012, 09:14 PM   #1
Can warped studs be fixed or replaced
Hi,
I have a detached garage separated into a front and back section. I am going finish the back room and hang drywall. However, some of the studs on the back exterior wall are warped. In one case, the stud sticks out about an eighth of an inch at the bottom of the frame. Is there any way to fix this? Can the stud be replaced? I assume the plywood on the exterior is nailed into the stud so that could be a problem.
Any ideas or do you just drywall right over it?
Thanks.
dw1256
dw1256 is offline   Reply With Quote
Old 07-15-2012, 09:19 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
usually drywall will float over minor discrepancies in the wall. a string line or a straight 8 foot 2x4 will help determine how straight the studs are in relation to each other in the wall.
hand drive is offline   Reply With Quote
Old 07-15-2012, 09:47 PM   #3
Framing Contractor
Originally Posted by dw1256
Hi,
Thanks.
dw1256
1/8" is nothing. Plane it down.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
mae-ling (07-15-2012)
Old 07-15-2012, 10:09 PM   #4
I thought about using a plane. Wasn't sure if others actually do that.
Thanks.
dw1256
Old 07-16-2012, 01:02 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 816
1/8"? I would love my studs being within 1/8".....
I just had to pull out a 12' 4x4 stud because it was sticking out about 1" from the wall.....
ddawg16 is online now   Reply With Quote
Old 07-16-2012, 02:40 AM   #6
Rewards Points: 2,202
I understand using 2 2x4 is better then a 4x4 for twisting.
Any built up beam is better than a solid beam for this.
mae-ling is offline   Reply With Quote
Old 07-17-2012, 09:27 AM   #7
I realize that drywall generally floats over minor discrepancies, but I hate when electrical boxes end up not being flush with the surface of the drywall because of this.
Old 07-17-2012, 11:17 PM   #8
Old School
Willie T's Avatar
If you get totally bent studs, here's an easy fix.
Can warped studs be fixed or replaced-straighten-studs-1.jpg   Can warped studs be fixed or replaced-straighten-studs-2.jpg
Willie T
Old 07-17-2012, 11:21 PM   #9
Thats what I did with mine, but I sistered a piece of 2X4 onto the side also!
Old 07-18-2012, 12:33 AM   #10
Yes sister plywood, 1x4, or 2x4
Why would electrical boxes be off? drywall should be attached to all studs.
Old 07-18-2012, 08:06 AM   #11
AHH, SPANS!!!
sometimes the stud is twisted in the wall and the electrician puts the box on the twisted stud. one side of the box sits flush and the other side angles back into the wall.
Old 07-18-2012, 10:20 AM   #12
Due to warping all of the studs are not lined up correctly, however, it is not really noticeable to the naked eye. Or at least my rookie eye.
I installed electrical boxes on various studs set for 5/8 drywall. When I went to hang the drywall, one or two of the electrical boxes ended up being 3/16" back from the surface of the drywall because the stud to the left was actually sticking out, preventing the drywall from laying flat across all of the studs.
Old 07-20-2012, 06:20 PM   #13
AHH, SPANS!!!
if the box sits further into the wall past the drywall a fire ring? is needed for the box
Old 07-21-2012, 01:00 AM   #14
I can see one side of the box being off on a twisted stud but not the whole box.
If this was the case then it means the drywall is not fastened to that stud.
How to add blocking w/ steel or metal studs bergerdude Building & Construction 12 04-30-2013 10:59 AM
Jacking Exterior Wall / Replacing Sill Plate Pittsville Building & Construction 2 06-16-2012 10:11 AM
How to repair rotted joists and studs? Snav Building & Construction 5 02-24-2010 11:35 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 04:20 PM
Help with straightening studs before drywalling genEus Carpentry 3 08-29-2008 03:12 PM
