Can Two Support Studs Be Removed In Attic? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-05-2011, 12:13 AM   #1
Can two support studs be removed in attic?
Hi,
There are two 2x4 in my attic I'd like to remove if possible. I'm just trying set up some flooring for storage. Its the only large area that can be used. The other parts of the attic have duct work or are hard to reach. They run diagonally from the studs to the joists. If I remove them can I use a different kind of support? Could I just shorten the studs that were used for support and renail them in? I've attached a picture of them. Any help would be appreciated.
TX1930 is offline   Reply With Quote
Old 01-05-2011, 05:59 AM   #2
Stay-at-home GC
What type of roof does the home have?
CplDevilDog is offline   Reply With Quote
Old 01-05-2011, 09:40 AM   #3
carpenter
It looks like to me those were put in while they built the walls to the house, till the walls were tide in to the joists i see no problem removing them.
samps70 is offline   Reply With Quote
Old 01-05-2011, 10:09 AM   #4
It has a Mansard type roof. The top is flat with steep sides. I was thinking the 2x4 were placed during construction for support and never removed.
Old 01-05-2011, 10:20 AM   #5
Stay-at-home GC
That was my guess too. Look like temp wall bracing.
As long as the corners of the walls are tied in properly (overlapping top plates and L' s) you should be able to get away with it. Alternatively you could run steel cable top plate to top plate with a turnbuckle before removing.
I would read my signature and check with an Engineer though.
venting and moisture in attic Alto Roofing/Siding 3 07-29-2010 10:31 PM
Attic Framing Confusion... Jamison1114 Carpentry 23 12-16-2009 03:17 PM
support for garage attic lkwebb Carpentry 5 08-22-2009 11:32 AM
Attic Frost cougar01 Building & Construction 5 01-28-2009 09:33 AM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
