Can Someone Tell Me What This Hole In My Basement Is(pics Inculded) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-26-2010, 05:52 PM   #1
Can someone tell me what this hole in my basement is(pics inculded)
I think it might be a sump pump crock. its right next to the furnace and the water heater. when the house was purchased it was sealed off with tape, and the tape has not been removed since. the home is older, > 30yrs old is my guess. Photobucket does not allow thumbnails, so here are the links
http://s861.photobucket.com/albums/a...t=IMAG0020.jpg
http://s861.photobucket.com/albums/a...t=IMAG0021.jpg
I am just curious to find out, thanks in advance
vande060 is offline   Reply With Quote
Old 12-26-2010, 06:43 PM   #2
kind of hard to tell from your pictures. why don't you pull that tape off and see whats there.
1910NE is offline   Reply With Quote
Old 12-26-2010, 07:29 PM   #3
I have no clue about the hole but I do have a question about the furnace. It appears to be the type with a condensing vent. Most of that type of furnace require that the combustion air be taken from the same atmospheric pressure zone as the vent termination. That would mean outside near the vent termination and yours appears to take combustion air from the basement. I cant see the other side of the furnace so I may be wrong.
Tigerloose is offline   Reply With Quote
Old 12-27-2010, 02:53 PM   #4
SteelToes's Avatar
Rewards Points: 150
supply
Furnace supply.
SteelToes is offline   Reply With Quote
Old 12-29-2010, 07:05 PM   #5
could it be a covered sump pit?
thedead is offline   Reply With Quote
Old 12-29-2010, 07:55 PM   #6
joed's Avatar
Rewards Points: 12,426
Sump pits don't usually stick up above the floor like that, but I can't think of what else it might be. What in the hole? What's that paper in the little bag on top of the covering?
Old 12-29-2010, 08:05 PM   #7
Rewards Points: 562
maybe
A basement entrance to a gold mine. You never know till you look. Open it up and look.
4just1don is offline   Reply With Quote
Old 12-29-2010, 08:39 PM   #8
Open it and show us!!!!!
General is offline   Reply With Quote
Old 12-29-2010, 09:00 PM   #9
Rewards Points: 198
vote4Pedro is offline   Reply With Quote
Old 12-29-2010, 09:23 PM   #10
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 822
If it were my house, I know what I would do. (Edit: I would jump right in and investigate.)
Aggie67 is offline   Reply With Quote
Old 01-04-2011, 09:31 PM   #11
looks like a old well
damifino is offline   Reply With Quote
Insulating basement - questions jtmann HVAC 7 11-19-2010 03:20 AM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
