Old 12-14-2010, 09:44 AM   #1
Can someone help with this cantilever beam problem?
Hi,
Can this concrete cantilever beam support for double story house? thanks
http://www.freeimagehosting.net/uploads/82c020da19.jpg
stevenchoon is offline   Reply With Quote
Old 12-14-2010, 10:46 AM   #2
In order to get the correct answer to your question you should contact a structural engineer in your area for your specific design and load.
epson is offline   Reply With Quote
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
Sagging Ceiling Joists - Adding Beam In Attic DoItMyselfToo Building & Construction 11 11-30-2010 07:20 PM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 09:15 PM
Ceiling joists support beam ptcamaro Building & Construction 3 06-17-2009 11:14 AM
Need advice on footer pier problem paredown Building & Construction 3 03-20-2009 10:08 PM
