Can Roofing Nails Be Used For Sheathing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 12:43 PM   #1
Question
Can roofing nails be used for sheathing
My contractor has used roofing nails to put sheathing up on one of my walls , is this ok?
Will it cause any issues I should be aware if?
Jcoppola is offline   Reply With Quote
Old 08-23-2012, 01:35 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
are they ring shanked roofing nails and how long are they? if it is the blackboard sheathing then it is fine but not so much for plywood in my opinion
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
Jcoppola (08-23-2012)
Old 08-23-2012, 01:43 PM   #3
I don't know exactly how long they are , but they are much longer than the nails that were used for the sheathing on the other walls. Also the sheathing is plywood.
Old 08-23-2012, 01:54 PM   #4
AHH, SPANS!!!
did they use a roofing nail gun for installation or hammer and nail?
Old 08-23-2012, 02:06 PM   #5
I believe a nail gun
They ran out of the other nails and just used what they had
I was not there, it was noticed after the fact so I am not 100% sure .
When we brought it to The contractor attention , he acted surprised but said " it was probly better cause the nails are bigger n longer" but we could tell him was just trying to cover himself
We really don't know if we should make a big deal n have him rip the new siding down and Replace it
Old 08-24-2012, 06:12 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Type of wall sheathing fasteners are governed by local and/or state stipulated Building Codes. This is especially so, based on region (some are more prone to storms and hurricanes than others + some are in seismic zones). Some sidewalls also fall under the shear wall category and require specific plywood installation patterns, with specific fasteners types, placed at specific locations and intervals.
(FWIW - You don't have your location listed anywhere).
Here is an example of wall sheathing fastener codes:
http://www.emmetcounty.org/uploads/7...Sheathing2.pdf
Also this: http://www.abag.ca.gov/bayarea/eqmap...PT08-Ch-3B.PDF
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
Jcoppola (08-24-2012)
Old 08-24-2012, 07:33 AM   #7
New Jersey
Old 08-24-2012, 11:18 PM   #8
Registered User
Rewards Points: 5,460
You are under both the IRC and IBC, ask locally. Here are the minimum Code basics;http://publicecodes.cyberregs.com/ic...002_par005.htm
Gary
Tags
contractor issues , sheathing , wall construction , wall foundation , wall material
Having problems with roofing nails humberguy Roofing/Siding 9 04-08-2014 09:44 PM
Manufacture History Roofmaster417 Roofing/Siding 6 02-23-2012 02:40 AM
roofing how many nails? huxhold1 Roofing/Siding 15 10-09-2011 06:09 PM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 04:49 PM
Source for roofing nails, 3" long, ring shank? buzzymalone Roofing/Siding 7 07-27-2009 10:58 AM
