Can This Interior Wall Be Removed? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-07-2010, 08:11 PM   #1
Can this interior wall be removed?
I am remodeling my post and beam structure mid-century ranch house, and came across an interior wall which I want to remove, Obviously, I am still going to leave the center post there to support the big beam. However, after removing part of the drywall,I am not sure if this whole wall is used for any load bearing and especially lateral support purpose, Any suggestion on what I should do? Thanks a lot.
Floorplan
Photo 1:
Photo 2:
onsight is offline   Reply With Quote
Old 04-07-2010, 08:18 PM   #2
One more picture looking at the other side of the wall
Old 04-07-2010, 08:21 PM   #3
And the whole span of the living room
And the whole span of the living room, you can see the post and beam structure.
Old 04-07-2010, 08:58 PM   #4
Registered User
Rewards Points: 526
It appears to be giving a lot of diagonal shear for that end of the big room with a 1x4 let-in to the wall, possibly one on the other end also. I would contact a Structural Engineer for liability advice for your Home-owners Insurance coverage.
Be safe, Gary
Old 04-09-2010, 03:07 AM   #5
thanks Gary, Yes, that 1x4 let-in brace is non-trivial. I will consider contacting an structural engineer
How to tell if all wallpaper glue is removed? CameraGuy Painting 11 04-04-2010 06:31 PM
Removed Chair Rail - Need to Patch Who Dey Painting 7 03-04-2010 01:43 PM
Removed carpet down to hard wood, quarteround needed? sweetsue777 Flooring 6 07-03-2009 06:25 AM
Do zinc strips prevent black algae AFTER algae removed? unclej Roofing/Siding 1 08-18-2008 05:29 PM
Popcorn ceiling has been removed, white powder on sills? daz59 General DIY Discussions 19 06-26-2007 06:28 AM
