#1 |
Can I use this sealant (3M FD150+) on Class B flue?
Hi,
I'm air sealing in the attic around the Class B furnace vent/flue (currently an open chase), which will include using roll metal flashing to create a 'block' around the pipe. I know that I need to use special fire-rated caulk to seal the seam between the sheet metal and the pipe. I have a tube of 3M Fire Barrier FD 150+ Sealant on hand (got on clearance before I knew I was doing this project) -- and am wondering if I can use it for this application. I'm no expert on fire code, so thought someone here might be able to help me decipher the product description, which follows: [From the 3M website:] 3M™ Fire Barrier Sealant FD 150+ -- Acrylic latex caulk used to firestop metal pipes and cables through concrete or gypsum and for use in dynamic head-of-wall systems. Designed primarily for sealing penetrations for non-combustible penetrants. 3M™ Fire Barrier Sealant FD 150+ has been tested and approved for single metallic pipe penetrations, common electrical and communications cable penetrations, as well as multiple penetrants through both masonry and gypsum wallboard constructions. 3M™ Fire Barrier Sealant FD 150+ has also been tested for use in fire rated construction joints. Here's a link to the product spec PFD: http://multimedia.3m.com/mws/mediawe...6EVs6E666666-- Now, I know I wouldn't be using this for concrete or gypsum, which are the materials referenced in the product description... but, the actual tube says "Bonds to most common construction materials." -- I'm wondering if this would likely apply to sheet metal? The description above says it is "for non-combustible penetrants". Does a Class B duct (meaning, as I understand it, that we have two smaller pipes running inside the larger/outside duct - it's not the direct flue/vent pipe on the outside) fall into this category? Any knowledge out there as to if this is the correct/code-compliant product for our application? I'd love to not have to run back out for other stuff (and save the $, as this was a great deal), if this would work. Thanks much! |
| Display Modes | |
| Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! | flipjarg | Flooring | 3 | 02-15-2010 10:09 PM |
| ASTM C920 Class 25 vs. Class 35 vs. Class 50 sealants | kooshball | Building & Construction | 0 | 12-14-2009 08:16 AM |
| PABCO: Do they treat their customers right since the class action suit? | Dodah | Roofing/Siding | 4 | 06-16-2009 03:09 AM |
| Laser Level - Eyewear Required? | mfleming | Safety | 19 | 01-05-2009 11:09 PM |
| Chimney Flue Hole | leezarrd | Roofing/Siding | 11 | 11-13-2007 05:18 PM |
