Can I Use Plywood For Interior Door Jambs? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-28-2010, 12:52 PM   #1
Can I use plywood for interior door jambs?
Hi,
I've got about 8 door jambs to install in my basement, and was wondering if I could use veneered 3/4" plywood instead of the standard finger-jointed pine.
I can't seem to find finger jointed pine at a reasonable price, and the pre-made kits seem to cost a fortune (95$ for a double door!). A sheet of 4x8x3/4 veneered ply is about 50$. That is enough to give me nine 4 9/16" strips of 8 feet, which equates to 3 double doors. Granted, I will have to route out the hinges and a door latch (for single doors), but I figure that is well worth the price differential.
Additionally, I figure that if I am really worried about door weight, I could always anchor my hinges directly into the frame instead of just the door jamb itself.
Off hand, I can't see anything wrong my plan, but wanted to see if anyone else had any ideas.
Thanks,
Eric
benze is offline   Reply With Quote
Old 09-28-2010, 03:24 PM   #2
I think if you were to check many prehung doors are done on plywood veneered jambs.
hayewe farm is offline   Reply With Quote
Old 09-28-2010, 10:20 PM   #3
" Euro " electrician
frenchelectrican's Avatar
I have see quite few do are on plywood veneered but some are on OSB as well { Yuck }
Merci.
Marc
Old 09-29-2010, 04:53 PM   #4
I think that where the problem lies, is when the casing is nailed into the side of the jamb, the plywood will tend to split.
if this happens, you will have a problem on your hands!
Old 09-29-2010, 11:07 PM   #5
firehawkmph's Avatar
Rewards Points: 1,822
If he uses an 18 ga. brad nailer for the edge of the casing that goes to the jamb he shouldn't have a splitting problem. I have used plywood for wide jamb extensions in basements and haven't had any problems with it. The other thing you may want to do is go to a real millwork shop that makes their own doors and see what they want for jambsets. Big box stores aren't the place to buy them, or the trim for that matter.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 09-30-2010, 09:00 AM   #6
Agreed. I've not had 18 ga. nailers split anything before either, save and except nails that deflected if they were too long.
Real millwork shops around here that make their own doors are not easy to find. I was actually quite surprised at the local big box; the pre-fab jambs that they are selling are only 1/2" jointed pine. Was expected at least 5/8 or 3/4.
Thanks for the tips!
Eric
Tags
door jamb , plywood
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
plywood damaged by water hendjl Building & Construction 4 11-03-2009 07:47 AM
How to install 3/8 underlayment plywood? dangdang Flooring 8 09-26-2009 05:21 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
