Can I Use This To Fill Gaps In My Garage Wall Siding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-14-2012, 02:41 PM   #1
Rewards Points: 260
Can I use this to fill gaps in my garage wall siding?
So I'm rehabbing my garage right now and in between each wall stud on the inside, there used to be tar paper. I ripped it all down the other day and uncovered a lot of gaps between the siding. Can anyone tell me if you can use that flexible rubber coating stuff like this to fill the gaps? I'd rather not have to use caulking or expanding foam. The gaps are less than 1/2" wide. Thanks!
Jesse
jpearson311 is offline   Reply With Quote
Old 05-14-2012, 03:53 PM   #2
Stay-at-home GC
Not sure what you mean by "Siding". The sheathing on the exterior of the wall or are we talking about the back of Board and Batten or Shiplap siding?
Pictures would help.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 05-14-2012, 03:56 PM   #3
Rewards Points: 260
Siding as in wood siding. Tongue and groove siding that is nailed horizontally on the walls. There are gaps in between the pieces of siding. Rather than having to run beads of caulk along the entire stretches of siding, I'd rather just use an aerosol and spray. However, I think I may need to use caulking.
Jesse
Old 05-14-2012, 04:15 PM   #4
Stay-at-home GC
Was the Asphalt paper on the outside of the wall directly under the Siding (between the siding and the studs)?
Old 05-14-2012, 04:28 PM   #5
kwikfishron's Avatar
Rewards Points: 414
What did you do that for?
kwikfishron is online now   Reply With Quote
Old 05-14-2012, 04:41 PM   #6
Stay-at-home GC
T&G Siding is not my business but from what little I know I would say it was a Rainscreen wall.
Not good
Old 05-14-2012, 04:43 PM   #7
Stay-at-home GC
Do you have any tape?
Old 05-14-2012, 05:18 PM   #8
Rewards Points: 260
Yes, but it was very old and damaged. That's why I took it down.
Old 05-14-2012, 05:18 PM   #9
Rewards Points: 260
Not a bad idea. What kind of tape?
Old 05-14-2012, 05:21 PM   #10
Rewards Points: 260
I did it because the garage was built in 1919 and the paper was most likely original. There was moisture built up behind it and it wasn't allowing the wood to breath. I'm going to replace it with something better, but just not sure what. That's why I started this post .
Old 05-14-2012, 05:23 PM   #11
Rewards Points: 13,458
Where just going to go round and round on this one until you post some pictures or at least better info.
Old 05-14-2012, 07:21 PM   #12
Stay-at-home GC
If it was a Rainscreen wall I think you are going to have some trouble reconstructing it from the inside.
Old 05-14-2012, 09:03 PM   #13
Rewards Points: 260
Attached are 2 pics. One with a cavity that I've already removed and the other with a piece still there. Thanks,
Jesse
Can I use this to fill gaps in my garage wall siding?-garage-walls-001.jpg   Can I use this to fill gaps in my garage wall siding?-garage-walls-002.jpg
Old 05-14-2012, 09:33 PM   #14
Not sure why you removed the felt paper that was on there.
Unless you plan on insulation and drywall on the walls there's no good reason to cover what you have now.
If you do go with insulation and drywall just staple up Tyvek between the studs.
Old 05-14-2012, 09:57 PM   #15
Rewards Points: 260
Much of the paper was damaged and there was moisture build up between it and the walls/siding. You can see it in the pictures. The problem is however that there are gaps between the siding and when it rains, water WILL get between them. As it already has.
I'm not really concerned about the insulation. I just don't want moisture/water to get in between the gaps and I really don't want to caulk the gaps. Very labor intensive. I just wanted a quick fix. Thanks.
Jesse
The Following User Says Thank You to jpearson311 For This Useful Post:
one cut (04-13-2013)
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Tyvek overlap with replacing siding one wall at a time Numb Building & Construction 54 07-01-2010 10:10 AM
Fill hole in foundation wall after Gas line was removed ctbfalcon Building & Construction 2 05-03-2010 08:16 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Wall Panel Over Sheetrock in Garage kypper Building & Construction 1 07-03-2008 07:57 AM
