Old 05-16-2008, 01:37 AM   #1
Question Can I use "Exposure 1" panels on a deck that will be covered with ceramic tile?
I understand that "Exposure 1" panels are suitable for uses that are not permanently exposed to weather, if I cover the panels with ceramic tile, will that be enough to protect the panels from the weather?
Also, can I thinset/mortor the ceramic tiles to the panels or do I need to put down cement board first?
Thanks for any advice you can provide.
CliffQ is offline   Reply With Quote
Old 05-16-2008, 03:53 AM   #2
General Contractor
MacRoadie's Avatar
I assume there's a waterproof membrane in there somewhere?
MacRoadie is offline   Reply With Quote
Old 05-16-2008, 10:05 AM   #3
Building codes guy, Mod
thekctermite's Avatar
Here's the APA's take on this.
Exposure 1 Plywood Panels are suitable for uses not permanently exposed to weather. Panels classified as Exposure 1 are intended to resist the effects of moisture due to construction delays, or other conditions of similar severity. These panels are manufactured with the same fully waterproof glues as used in Exterior plywood; however, because of other compositional factors that may affect bond performance, only Exterior panels should be used for long-term exposure to weather. Exposure 1 panels may, however, be used where exposure to the outdoors is on the underside only, such as at roof overhangs.
APA Rated Sheathing Exposure 1 plywood, commonly called CDX, is oftentimes confused with an Exterior plywood panel and misused in applications. It is important to understand the difference between these classifications in order to select the best panel for your project.
Exposure 1 plywood has less voids, but the same glue. Otherwise the differences between it and rated sheathing are few.
You should not tile directly to the plywood!!!!! You must put down 1/2" tile backer. A waterproof membrane must be installed under the tile backer to prevent moisture from migrating to the plywood.
thekctermite is offline   Reply With Quote
Old 05-16-2008, 02:10 PM   #4
Question
Thanks for the advice, I really appreciate it.
Is there any or much of a difference between 'exposure 1' OSB and 'exposure 1' plywood?
Any recommendations as to what waterproof membrane to use and what type of grout and sealer to use?
Thanks again for the advice.
Old 05-16-2008, 03:52 PM   #5
I'd suggest plywood. I'd also suggest priming and painting all surfaces.
There's some good tile guys in the flooring forum that could give you a good suggestion for membrane and tile materials. You should post that question there.
Old 05-16-2008, 07:18 PM   #6
Thumbs up
Thanks I'll follow-up with the flooring forum. It's always easier to get it right the first time than trying to fix problems after the fact.
Old 05-17-2008, 08:45 AM   #7
dont forget to add a drainage board above the waterproofing and make sure to align the groves with the direction of desired drainage
ncgrogan is offline   Reply With Quote
More On This Topic
Spanish tile has been used for centuries on roofs, and some of these old, historical roofs are still in existence. There are times when repairing a Spanish tile is necessary. Read this eHow to learn more. Read More »
Vinyl tiles are one of the most commonly used floor coverings in homes today. The flooring comes in a variety of colors, textures and styles. Vinyl tiles are durable, decorative and easy to maintain. Follow the steps below to keep your vinyl floor in... Read More »
Substrates for Tile Mosaic
Substrates for Tile Mosaic by Expert Village
Right now we're going to talk about substrates. Substrates is just a fancy word for what you glue your tiles to. Today I've chosen this little mirror for us to use. I liked it, it was a good first project because it's small and it's also got a mirror... Read More »
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. Barrel cap trim is installed from the bottom up course to course with the panels. Install the end disc, position the first cap on the rig with the rear... Read More »
A wood planter can add beauty to your home and is the most preferred material for planters. The type of wood you buy for a planter will depend on what you are planting; some woods are not recommended for vegetables or food sources. Follow these tips to... Read More »
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 08:12 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 08:19 PM
Installing Solar Panels on Your Home or Business doctorhouse Building & Construction 6 09-04-2008 11:23 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 05:31 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 04:26 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
