Originally Posted by yummy mummy
After I prime my new walls, (after I taped it) and I notice that there may by a spot that may need touch up, whether it be adding more compound or slightly sanding, would I be able to do that?
Of course you can. The primer will actually help to show the blemishes better. Just make sure that after you fix those areas and sand them, that you re-prime them again, or they will flash.
Also, do I need to do 2 coats of primer on my fresh drywall or is one coat ok. Would 2 be better? Would it hide more?
One coat should be fine. If you have picked out the color, or colors for your areas/rooms, you are better off tinting the primer for that room, the color of the walls.
Obviously, the ceiling primer can be white.
