Can I Still Caulk Hardi Plank After A Rain - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-11-2009, 10:48 AM   #1
Can I still caulk hardi plank after a rain
can i still caulk hardi plank after a rain
vbflmt is offline   Reply With Quote
Old 09-12-2009, 10:39 AM   #2
Rewards Points: 1,552
I would think once dry you should be fine.
bob22 is offline   Reply With Quote
Old 09-12-2009, 10:50 AM   #3
yep, no problem, as long as it is dry when you are caulking.
What are you caulking? The end of the boards where it meets the trim?
derf36 is offline   Reply With Quote
Old 09-14-2009, 08:23 AM   #4
hardi plank
yes. We did caulk even though the weather was drizzly. the prob. we ran into was the 1st 2 boards closest to the ground caulk washed out. other than that everything still looks good. thank you for your reply
vbflmt
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 03:01 PM
Hardi plank - staining vs painting acdrey Building & Construction 36 03-22-2015 11:53 AM
hardi plank jwms Building & Construction 5 05-17-2009 12:07 AM
Hardi board plank siding over T1-11 bluefitness Building & Construction 3 12-19-2008 08:55 AM
