Can I Replace Sill Plate Under A Single Joist? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-17-2010, 09:43 AM   #1
Can I replace sill plate under a single joist?
The sill plate is rotted under one of the floor joists in my basement. Can I simply replace the rotted section under this single joist (10" section)? Or should the replacement piece span 2 or 3 joists?
Does the replacement piece need to be nailed in to the concrete?
How should the joist end be sistered? I can't access the other end of the joist due to air ducts.
The rim joist is also slightly rotted. What are the recommendations for replacing sections of rim joist? It will be supporting a deck ledger after this is repaired.
kwerk is offline   Reply With Quote
Old 09-17-2010, 10:27 PM   #2
jlhaslip's Avatar
Rewards Points: 2,186
first, find out where the moisture is coming from and fix it.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Damaged Sill Plate/ Rim Joist bignateyk Building & Construction 4 04-28-2010 08:09 PM
rotted sill plate, joist ends and stud bottoms oh my. slowjo Building & Construction 16 05-02-2009 09:43 PM
How much does it cost to replace part of a sill plate? twilightcall Carpentry 3 06-05-2008 09:51 AM
Sill plate damage from water. Do I need to replace? twilightcall Building & Construction 4 06-05-2008 07:55 AM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 10:57 AM
