Can I Remove This? Bricks Above Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-01-2013, 04:15 PM   #1
Can I remove this? bricks above beam
In my basement ceiling, but only above the support beams, I have what looks like grey bricks mortared in between the joists. What function do they serve? Can I take them out? I'd like to eventually run new pipes and wiring through there.
Rekonn is offline   Reply With Quote
Old 06-01-2013, 04:40 PM   #2
Old School
Willie T's Avatar
You sure that's mortar, and not foam?
Willie T
Old 06-01-2013, 05:17 PM   #3
Maybe plaster? I don't think it's foam. I can break a chunk off and crumble it further in my hands. I see home hair in it too.
Old 06-01-2013, 06:22 PM   #4
Maybe it's for fireblocking? The ceiling was finished before I started taking it down.
Old 06-02-2013, 06:57 AM   #5
DIY staff
Rewards Points: 7,174
Looks like fire blocking to me----rather old house? 1920s 1930s?
Old 06-02-2013, 10:35 AM   #6
Wow, yes, built in 1928.
Old 06-02-2013, 11:02 AM   #7
Ok, so the brick/plaster fireblock is necessary. But, I can knock it out, run some pipes/wires, and then put it back, right? I'm thinking just reuse the bricks, and then something else that'll do the job the plaster is doing now. I was initially thinking Great Stuff Fireblock foam, but the reviews on amazon are bad. Reviews say it burns just like regular foam, just colored orange. One review said it didn't pass inspection and he had to rip it out and replace with something called intumescent caulk. What do you guys recommend?
The Following User Says Thank You to Rekonn For This Useful Post:
oh'mike (06-03-2013)
Old 06-02-2013, 11:27 AM   #8
AHH, SPANS!!!
Rewards Points: 1,166
fireblocking can be made from wood in some cases/most cases and then use the fire foam to fill around the perimeter of the fire blocking. in fact, fire block before pipes wires are run and you can cut the pipes/wires to fit in tight leaving less air spaces to fill later...
hand drive is offline   Reply With Quote
Old 06-02-2013, 02:40 PM   #9
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Fireblocking, and it might also help the joists from twisting or otherwise moving, I would put them back if removed.
Sculpture scholarship recipient, 2008
Asbestos information: http://www.diychatroom.com/f98/asbes...pt-1-a-181840/
RWolff is offline   Reply With Quote
Old 06-02-2013, 02:46 PM   #10
Rewards Points: 502
Yes; most people wrongly assume that timber is something you DON'T use for fire-stopping.
Used in a suitable thickness in a gap, the timber charrs in a fire, and this insulates it from the heat and prevents further degredation.
Where I live there are some old Victorian textile warehouses where the floors are of timber joists nailed side-by-side, so the whole floor is solid timber. These often survived in a fire.
tony.g is offline   Reply With Quote
Old 06-02-2013, 09:47 PM   #11
Registered User
Rewards Points: 5,216
Remove and replace with solid wood per code; http://www.reedconstructiondata.com/...g-codes/maine/
IBC, note "other approved means" was not what you have for turn-over, lol; http://publicecodes.cyberregs.com/ic...?bu2=undefined
Gary
Old 06-03-2013, 05:58 AM   #12
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,842
Be sure to check that material for asbestos or use proper PPE. Given the age, there is a potential for that in that older material.
The Following User Says Thank You to Windows on Wash For This Useful Post:
r0ckstarr (06-03-2013)
Old 06-03-2013, 09:49 AM   #13
Haverhill Trade 1965
Are the photos from one side only, and is the other side the same? It looks like they are over a carrying beam. I agree it looks like fire stops, and wood works because it is intended to stop the airflow that will draw the fire up a wall, from a horizontal space into a vertical one, or vise-versa, slowing the progress of fire. Even the bricks will not work if the air spaces are not sealed
Duckweather is offline   Reply With Quote
Old 06-03-2013, 09:50 AM   #14
Bill Kearney
Rewards Points: 1,174
fireblocking can be made from wood...
Sure, the idea isn't just to be fireproof, it's to delay the path of a fire long enough for people to get out and potentially limit the extent of the fire's damage.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
hand drive (06-03-2013)
Old 06-04-2013, 02:21 PM   #15
I forget if the photos are from the same side, but it does look the same from both sides. And yes, they're over the carrying beam.
Putting up a beam - Need Help? kgagnon7 Building & Construction 41 09-09-2012 09:33 AM
Flush framing basement beam cbrc5eric Building & Construction 2 08-14-2012 12:28 PM
Support I beam needed ThisOldH0use Building & Construction 28 05-16-2012 10:10 AM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 11:56 AM
