Can I Put A Vinyl Tub Surround On DensShield Backer Board - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-03-2009, 11:01 PM   #1
Can I put a vinyl tub surround on DensShield backer board
I want to put a 5 piece tub surround over DensShield backer board. Should I use PL 700 or thin set to stick it on? Is it O.K. to put vinyl on the backer board?
Thanks Ioniz
ioniz is offline   Reply With Quote
Old 07-04-2009, 06:04 AM   #2
Not sure what you mean by "stick it on". Fiberglass tuns often need support underneath, which is usually mortar or similar. But that is to mold to the bottom of the tub and provide support at the bottom, not necessarily adhesion. And I see no reason not to do it backerboard. I would use a skim coat of drywall compound to take off the roughness.
Always follow the manufacturers directions!!!
Old 07-04-2009, 03:15 PM   #3
Just Bill
What I want to do is (glue) a vinyl tub surround to DensShield backer board. What I want to know is, will the PL 700 that comes with the surround kit adhere to the backer board? Will thin set used for tile adhere to the vinyl? What's the best route. The tub is an old metal type (not cast)
Thanks ioniz
Old 07-04-2009, 03:30 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
this is not from a pro but (that never stopped me before)
I would suggest applying over Denshield would be fine. I believe the proper adhesive would be based upon the material you are applying which, in this case, is the vinyl so the adhesive supplied with the tub surround would be proper.
Just as support for this, on the job I am currently working on,( a 600,000+ sq ft hospital) Densshield was installed in a lot of places. Some places have back and side splashes for the sinks made from Corianne. These were installed using PL something (can't remember, seems like 200 but could have been 700). FRL (basically plastic laminate sheets) were also installed using the same adhesive. The FRL would be a similar installation to what you are doing although they are not in the shower area. I do not believe that would make any difference though.
Caulk any edges to prevent water infiltration behind the overlay.
I would NOT use thinset as thinset is designed to be used under (or behind) a very hard rigid surface. It is not flexible so the flexibility of the laminate on the board (the board will give and flex to some extent) would most likely result in failure of the thinset.
Old 07-04-2009, 05:12 PM   #5
nap
Thanks. Had pretty much decided to go that route although I may still decide to tile the damn thing
ioniz
Old 07-04-2009, 05:31 PM   #6
nap
You talking to me?
nap's Avatar
I like tile. I hate grout. Tough decision for me.
Best of luck.
best way to fasten backer board? ponch37300 Flooring 19 04-10-2017 08:46 PM
installing backer board over particle board bob mac Flooring 6 07-16-2013 03:15 PM
Hardie backer board DXS General DIY Discussions 2 03-17-2009 05:40 PM
How Do I Patch Tile Backer Board? rajrae Tiling, ceramics, marble 1 11-17-2008 09:43 PM
Painting DensShield tile backer board warriorfox Painting 2 05-15-2008 04:08 PM
