Old 07-27-2010, 09:34 AM   #1
can i mix asphalt sealer and cement ????
hi , going to start fixing my asphalt driveway.
got a few bad spots where asphalt is completely gone . down to sand.
and lots of cracks.
i was wondering if it was possible to mix cement with asphalt sealer , then pour that over pot holes , smooth off . then later completely seal driveway ????
jake trudell is offline   Reply With Quote
Old 07-27-2010, 03:08 PM   #2
nap
You talking to me?
nap's Avatar
I doubt it would be successful. Cement functions by hydrating, that is, absorbing water. That initiates a chemical reaction that results in the cement becoming hard. If you mixed it with asphalt sealer, you would pretty much prevent any moisture from getting to the cement and as such, prevent it from hydrating.
Reparing "Live Bait Well" Cement walls Roaddog Building & Construction 2 07-09-2009 07:02 PM
Laminate on Basement Cement floor... helpless handyman Flooring 12 02-19-2009 04:33 PM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
Need help:I painted cement floor & now need to seal it ggsmom Painting 2 10-29-2008 02:57 PM
How to smooth a rough aggate concrete floor lotstodo Flooring 1 08-18-2008 10:23 PM
