Can I Just Fill It In With Concrete? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-16-2011, 10:02 PM   #16
Missouri Bound's Avatar
Build a wall out of dimensional lumber the same height as the bricks. Put a piece of 1/2" plywood on the front, and a piece of 3/4 on the top, covering your wall and the brick. Paint the top piece, both sides, before you install it. Setting the heater on wood will help prevent early corrosion of the water heater.
Old 12-17-2011, 09:44 PM   #17
Send a message via Skype™ to kutsyy
Well, at the end I ended up with brick. It is not as bad as I thought
End result is not perfect, but pretty good for first timer (I think), and it does look better than concrete. Comments?
As for wood, yes by code I could just build it out of wood, but given that the rest is brick it would not look good at all, plus I personally don't feel comfortable putting 75gal water heater on wood platform (yes I know, but...). There will be a plywood over the brick under the water heater to prevent corrosion.
kutsyy is offline   Reply With Quote
The Following User Says Thank You to kutsyy For This Useful Post:
Snav (12-17-2011)
Old 12-17-2011, 09:46 PM   #18
Looks great. Glad you are going to use the wood.
Old 12-17-2011, 09:56 PM   #19
Military Mom of 4
Snav's Avatar
That's awesome! You did a GREAT job on that - and got to it quick.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 12-17-2011, 09:58 PM   #20
Rewards Points: 582
wow can't even tell any work was done looks like it was always there great job....
Old 12-17-2011, 10:06 PM   #21
Military Mom of 4
Snav's Avatar
A benefit to doing it with bricks right now is that the present water issue won't hinder the curing process or weaken it at all.
concrete fill pricml Building & Construction 3 08-31-2011 04:44 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 01:20 PM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 03:49 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
