Can I Insulate First Floor Exterior Wall The Same Way As Basement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-23-2009, 11:34 AM   #1
Rewards Points: 33
Can i insulate first floor exterior wall the same way as basement?
Basically I wanted to use this procedure -> http://www.owenscorning.com/worldwid...D=9&Language=1 to insulate my first and second floor exterior walls.
Is it ok do to?
the punisher is offline   Reply With Quote
Old 04-23-2009, 11:58 AM   #2
BIGRED
Rewards Points: 252
You could, but aren't your above grade walls wood framed? Don't you want to insulate the wall stud cavities? If you use the metal channels to hold the foam make sure you aren't going to need the wall's wood framing strengh later on down the road. All your interior wall coverings will have to be anchored to those narrow metal channels you see in the pictures.
Grampa Bud is offline   Reply With Quote
Old 04-23-2009, 12:03 PM   #3
Rewards Points: 33
The house is made of a double brick wall and the joists are sitting on those walls. So basically the current wall that is there is not holding anything, it is just finishing. ( lathe and plaster) So once i remove that i am left with a bare concrete wall.
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 03:41 PM
Necessary to insulate basement ceiling between joists? yummy mummy Building & Construction 12 02-06-2009 11:19 PM
Framing in basement attached to concrete blocks, how to insulate? drnormie Remodeling 11 01-21-2009 05:40 PM
Insulate a basement walkout door? Shamus Building & Construction 3 09-25-2008 11:10 AM
Where to insulate in basement...? DIY4EVER Building & Construction 5 07-27-2007 12:33 PM
