Can I Hang Sheet Rock On 24' 2x4 Trusses? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 06:24 PM   #1
Can I hang Sheet Rock on 24' 2x4 trusses?
I just had a 24x24 garage built and the builder used 2x4 trusses 24" on center. I would like to insulate and rock the ceiling. is it okay to hang 3/8 Sheetrock and 10" insulation?
topshelf1957 is offline   Reply With Quote
Old 09-20-2010, 06:52 PM   #2
kwikfishron's Avatar
Rewards Points: 1,022
5/8 yes, 3/8 no.
Not sure what 10&quot insulation is.
kwikfishron is offline   Reply With Quote
Old 09-20-2010, 07:18 PM   #3
Old School
Willie T's Avatar
10" insulation doesn't weigh enough to even worry about.
Willie T
Old 09-20-2010, 07:33 PM   #4
Sorry the 10&quot came out in the blog. it was supposed to be 10 inches.
Same thing with the joist they are 24 inches on center.
So it will be okay to hang 5/8 sheetrock. it wont sag or over stress the trusses?
Old 09-20-2010, 07:33 PM   #5
I would put some strapping up to hold the board
Boston Bean is offline   Reply With Quote
Old 09-20-2010, 10:04 PM   #6
Registered User
Rewards Points: 526
Check your plans stapled to the building permit.
Gary
Old 09-21-2010, 02:52 PM   #7
Tizzer's Avatar
Rewards Points: 470
^^^ Or the package that came with the trusses. We framed whole houses with trusses on 24" centers but the truss package specified where & how many stiff-backs on the truss to keep them rigid.
Whats wrong with plain ole 1/2" sheetrock?
Tizzer is offline   Reply With Quote
Old 09-22-2010, 04:47 PM   #8
with 24" on center 1/2" drywall may sag unless you buy it from a drywall supplier and get designated ceiling board which is stiffer than regular 1/2". On all jobs with 24" on center we use 5/8" drywall and never have any problems with sagging or wavy ceilings, which you may get with 1/2", I said may, not always but why risk it, use 5/8".
newfie49 is offline   Reply With Quote
Old 09-22-2010, 07:02 PM   #9
Thanks for the input. My concern was more with the 2x4 trusses than the sheet rock.
It looks like 5/8 is the way to go. Someone mentioned stiff backs for trusses? Never heard of them. Are they expensive, easy to install?
I was thinking of gluing and nailing plywood strips to the sides of the 2x4's to give them more strength.
Any thoughts? Am I worrying to much?
Thanks,
Bill
Old 09-23-2010, 06:52 AM   #10
Did the builder do a quality job of framing? If so I wouldn't worry about extra plywood strips etc, just go ahead and drywall. I have installed drywall in garages and houses with 24" on center, using 5/8 drywall on the ceilings and never had any problems.
The Following User Says Thank You to newfie49 For This Useful Post:
BigJim (09-24-2010)
Old 09-23-2010, 11:38 AM   #11
They make 92 5/8 and 104 5/8 studs for a reason.
All lids should be 5/8.
jiggyjack is offline   Reply With Quote
Old 09-24-2010, 01:10 AM   #12
You really don't need to strengthen the 2x4s, keep in mind those trusses are engineered to be more than strong enough, the webs make up for what appears to be a skimpy 2x4. My 24'x32' garage has 2x4 trusses, I built it last year, and the trusses are still perfectly true, even after heavy snowfall. I have a hip roof and even the Hip truss is all in 2x4.
As for the gyproc, couldn't you just forens the ceiling on 16"?
ogagnon is offline   Reply With Quote
Old 09-24-2010, 12:35 PM   #13
I can tell you from experience that it will be ok aesthetically (drywall will not sag if that is your concern); my basement ceiling was done like this- 24" oc trusses with 1/2 drywall ceiling. Whether it is code compliant is another matter.
Steve_P is offline   Reply With Quote
Old 09-24-2010, 02:59 PM   #14
Tizzer's Avatar
Rewards Points: 470
Thanks,
Bill
I mentioned stiffbacks as a mean to keep the bottom cords stiff & true. You'll be able to see if the contractor nailed anything on the attic side of the truss bottom cords. A 1X4 or 2X4 is the norm here.
Sheet Rock Over Concrete atmironov Drywall & Plaster 3 08-13-2010 03:17 PM
wet sheet rock amy@jccturf.com Drywall & Plaster 5 06-11-2010 02:10 PM
Back Splash Tile Over Old Sheet Rock? Stcrosby Remodeling 3 01-03-2010 12:46 PM
Sheet rock (1/4") in trailer house sagging chrissygarden Building & Construction 4 08-19-2009 10:53 PM
Painting over messed up sheet rock. emilyiam Painting 2 03-24-2008 04:00 PM
