-   -   can I get rid of this ugly thing? (http://www.diychatroom.com/f19/can-i-get-rid-ugly-thing-140083/)
dwcopple 04-12-2012 12:35 PM
there is a decorative (must be) header separating the dining area from the living area that I would like to remove and sheetrock over. Can I do this? This is not on the centerline of the house and I looked in the attic and there is no double beam or anything near that point.
http://i3.photobucket.com/albums/y74...412_123116.jpg
Would I just pry the side off and fill the area with a patch piece to tie the rooms together?
joecaption 04-12-2012 12:39 PM
Unless someone was there to look it over to figure out why it's there that knew what they were looking at I would not remove it.
Looks like an undersized header where someone open up the wall. But no way to really know without being there.
cortell 04-12-2012 12:44 PM
If you're sure it serves no function, then sure! But it could be a bulkhead of some sort for plumbing or electrical work that the previous owner did the "easy way". You need to check not only the attic, but the adjacent rooms. Also, I hope you're really good at drywall mudding and texturing (?--can't tell from the pic). Sometimes these sort of things end up leaving a scar that's worse than what was previously there. Not trying to discourage you. Just saying you should think this through carefully :-)
sublime2 04-12-2012 12:50 PM
One way to know for sure,pry 1 side off and see what's behind it.
md2lgyk 04-12-2012 01:12 PM
It would be much less noticeable if you painted it the color of the ceiling.
cortell 04-12-2012 01:15 PM
Wow. You really think someone would have replaced a load bearing wall with a 4x over that span??? My god. Lets hope not. Are joists in the roof perpendicular to that "thing"? If so, can you report their length and their spacing? Also is there ANYTHING in the attic above it...even a platform for storage?
cortell 04-12-2012 01:18 PM
And the joist depth
dwcopple 04-12-2012 02:01 PM
Attic is empty. Roof joists are perpendicular yes. I will be up there saturday snaking some romex and will take pics and measure.
cortell 04-12-2012 02:13 PM
OK. Well, with joist length, depth and spacing (and a pic of the attic wouldn't hurt), we should be able to figure out if it's load bearing or not.
dwcopple 04-12-2012 02:43 PM
what do you mean by depth? Height of board used?
cortell 04-12-2012 02:54 PM
Yep. By example, the depth of a 2x12 joist is 12 nominal inches, 11-1/4 actual inches
thatbobguy 04-13-2012 02:17 AM
It may be there to hide the fact that one ceiling was noticeably higher than the other when (if) the wall was removed.
So if you're gonna pry it loose for a looksee, be sure not to damage it.
dwcopple 04-13-2012 07:18 AM
hmm don't think so, ceilings are level.
Joe Carola 04-13-2012 08:52 AM
That is seen in many homes where that load bearing wall is removed and a beam is put it that is taller than the joists. Therefore the bottom of the beam is lower than the bottom of the ceiling. Cannot cut that out.
cortell 04-13-2012 09:05 AM
That has already been ruled out: "I looked in the attic and there is no double beam or anything"
