Can I Frame A Wall With 2x2's? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-01-2013, 09:00 PM   #16
Registered User
Rewards Points: 4,914
http://www.buildingscience.com/docum...r-requirements
Gary
Old 10-03-2013, 11:18 PM   #17
Rewards Points: 172
The wall was built wrong because they ramset furring strips right to the block wall, screwed a second strip to the first ones, then smashed 3.5" fiberglass insulation under the drywall, which did cause moisture problems. I rerouted spouting outside the house. There will be electrical. I cant move the door because it's right at the bottom of the basement steps. And narrowing it is going to add more work than I think I really need to do. Especially since on the other side of the door the wall is textured, and they used a certain type of old barn wood that I'll never be able to match up. I'm just wondering what all could possibly go wrong if I just framed a wall using 2x2's.
nateshirk is offline   Reply With Quote
Old 10-05-2013, 07:01 PM   #18
Registered User
Just keep the basement air from reaching the concrete wall; https://docs.google.com/viewer?a=v&q...qqQTqzkXnRJfcQ
Gary
Old 10-05-2013, 07:11 PM   #19
Nateshirk: what is spouting? I've never heard of it
RoyalAcresRod is offline   Reply With Quote
Old 10-05-2013, 09:53 PM   #20
Rewards Points: 1,426
I'm guessing downspouts. Rain gutters.
mikegp is offline   Reply With Quote
Old 10-10-2013, 10:51 AM   #21
Rewards Points: 172
Yes. The gutters outside needed redirected.
Old 12-06-2013, 12:55 AM   #22
Rewards Points: 172
So, I could just install 2" xps, "tapcon" some 2x4's flat against the xps every 24 inches, and be all good, right? That's 2in.(xps)+1.5in.(2x4)+.5in(drywall)=4inches. Is there any reason this wouldn't work?
Wall damage below bathroom quaker87 Plumbing 8 02-28-2013 05:56 PM
Replace masonry wall - feasibility mwpiper Building & Construction 12 01-13-2012 12:36 AM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
