-   -   Can I frame over an existing tile floor? (http://www.diychatroom.com/f19/can-i-frame-over-existing-tile-floor-66480/)
stavpeter 03-10-2010 01:04 PM
Can I build a non load bearing partition wall to divide a large room with an existing tile floor (tile on concrete) without cutting out the tile? If so, how should the bottom plate be fastened to the tile floor? Tiles are 12x12. Fastening top plate not a problem. Thanks for any advice.:)
oh'mike 03-10-2010 06:17 PM
Either drill holes and use TAPCON screws or use liquid nails. I recently finished a basement that has hydronic heat---No holes in that concrete!!! Liquid nails did the job.--Mike--
tpolk 03-10-2010 06:24 PM
i agree with mike plus having a slight cushion between bottom plate and tile is a plus
firehawkmph 03-10-2010 06:29 PM
One other thing to add, place your tapcons in the mortar joints, it will be much easier to drill rather than drilling the tile.
Mike Hawkins:)
stavpeter 03-10-2010 09:02 PM
Thanks...
...tapcons in drilled holes thru mortar if possible it is. Will also put 1/8"x2" foam packing ribbon I have under bottom plate.
