Old 01-20-2013, 09:30 PM   #1
Can I drill one more hole on top plate for drain pipe
Hi all, I'm looking to relocate some drain pipes and I'm wondering if I can drill holes on the top plate of the wall to run this pipe?
Seen on the image, there is already a central vac pipe (gray pipe) running through this double 2x6 top plate. I want to reroute the drain pipe (black pipe shown in image) to adjacent (location shown by red circle) to the existing central vac pipe. So I'm wondering if it's okay to drill a hole there when there is already another hole drilled for the central vac pipe?
This is a load bearing wall with 2x6 framing.
Thanks!
jsunsun is offline   Reply With Quote
Old 01-20-2013, 09:46 PM   #2
Yes. Joist is sitting on stud and the corner does not look critical, such as outside corner.
carpdad is offline   Reply With Quote
Old 01-20-2013, 10:10 PM   #3
Thanks so much!
Just want to supply more information. This is actually a small closet within that laundry room that I wish to knock out to create a more open laundry room. Because the drain pipe sit inside the closet wall, hence I want relocate it once that closet is eliminated.
I've attached a floor plan of that area. The red line top plate represent the closet wall shown in red on the floor plan. The blue line top plate represent the load bearing wall shown in blue on the floor plan.
Adding this extra information, just want to double confirm that it's still ok to drill the extra hole?
Thanks!
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Dryer duct hole thru band joist & floor joist justplumducky General Discussion 12 10-05-2010 01:31 PM
Latch plate with larger hole tjtexas Carpentry 3 08-14-2010 05:40 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
good drill for big hole saws? jimmy21 Tools 9 09-08-2008 06:10 PM
