Can I Demo These Steps With This Drill? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 08:36 PM   #1
Rewards Points: 260
Can I demo these steps with this drill?
I need to demo these steps because I'm extending my deck all the way down to the edge of my porch slab. I'm using a non-explosive demoing agent so I have to drill 2 holes in each step at 1' apart. You can see the steps in the attached pic. I own this drill already and wondered if it will work for this job. The holes need to be 1-1/2" in diameter and need to go through ~90% of the concrete (not all the way through). Also, can you send me a link of the type of bit I should use? Here is the drill that I have already. Thanks!
Jesse
http://www.craftsman.com/shc/s/p_101...le+Power+Tools
jpearson311 is offline   Reply With Quote
Old 03-08-2010, 09:11 PM   #2
Journeyman Wireman
Rewards Points: 150
Rent a big rotory hammer. Though I'm not sure you can get 1 1/2" bits for a rotohammer. We use a Dewalt "Macho" to blow through foundations or drive ground rods.
Jupe Blue is offline   Reply With Quote
Old 03-08-2010, 09:26 PM   #3
Rewards Points: 81
Yeah, a hammer drill will make a night and day difference with that job. I bought one from Harbor Freight when it was on sale for $49. I don't use it all that often -- but when I do use it, I love it.
Although I'd research 1-1/2" bits before you commit to any piece of equipment.
Why not just rent a jackhammer and take it apart?
Jack Olsen is offline   Reply With Quote
Old 03-08-2010, 09:33 PM   #4
Rewards Points: 260
I can use a smaller bit, but I'll just have to drill more holes. Will this drill work?
http://www.sunbeltrentals.com/Equipm...0060&catid=s44
Also, I've been looking all over for a drill bit for this job and I can't find anything. Recommendations?
Jesse
Old 03-08-2010, 09:35 PM   #5
Rewards Points: 260
Wouldn't I need an air compressor to use a jack hammer? Plus, I'm trying to keep it as quiet as possible .
Old 03-08-2010, 09:36 PM   #6
King Construction Inc.
if you want to get it done u need a jackhammer, unless your not on a schedule then you can do it your way but your still going to need a pretty good size hammerdrill to get an 1 1/2inch diameter hole. you can get a smaller electric jackhammer that would work perfect... you could also just drill a bunch of 3/4 holes and bust it up with a sledgehammer (much more labor intenceive) also if the steps have steel you are probably going to need a right angle grinder or a concrete saw to complete the clean up.
nking is offline   Reply With Quote
Old 03-08-2010, 09:39 PM   #7
Rewards Points: 260
Ok. I can use a 1-3/8" bit too. I may be able to use a 1" too, but that's about the smallest.
Old 03-08-2010, 10:04 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Jesse
That drill will do the job. You may be able to rent the bit, or it may be required that you buy one.
If you have to buy it, hold on to your hat, it will be expensive.
You can also rent an electric jack hammer.
Old 03-08-2010, 10:09 PM   #9
Have you tried a sledgehammer yet ?
A lot of these are cement over hollow blocks to save $$ on concrete
Old 03-09-2010, 08:54 AM   #10
Rewards Points: 260
I haven't tried a sledge yet, but a lot of people have been saying I should. They seem too big for a sledge. Although, on the side of the steps, there are lines that run along the side where each run of the step ends. You can kind of see them in the pictures. Does this mean that they may be stacked in some way?
Jesse
Old 03-09-2010, 09:34 AM   #11
Tom Struble's Avatar
Rewards Points: 2,002
try hitting them with a sledge first
Tom Struble is offline   Reply With Quote
Old 03-09-2010, 09:44 AM   #12
Jesse
Solid concrete will not have lines like that
Looks like cement blocks stacked & then coated with concrete
Sledge & safety glasses
The Following User Says Thank You to Scuba_Dave For This Useful Post:
jpearson311 (03-09-2010)
Old 03-09-2010, 10:06 AM   #13
Rewards Points: 260
Looks like cement bloks stacked & then coated with concrete
Right on! I'm on it! Thanks!
Jesse
Old 03-09-2010, 11:13 AM   #14
Newbie Bill
Rewards Points: 518
Please report back what you find. I'm curious.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 03-09-2010, 11:16 AM   #15
Rewards Points: 260
Will do.
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
Re-staining inside steps saggdevil Painting 10 09-20-2009 07:40 PM
Determining correct drill key MRTIGRE General DIY Discussions 3 06-04-2009 02:58 PM
