Old 10-12-2012, 07:47 PM   #1
Can I cut this wood block out and then just nail it back in?
This wooden block is in the way of me soldering, can I just cut it out and then reinstall it? Is that safe? I'm talking about the wood block that is lighter in color and is in the center of the photo. Thanks so much for the advice just don't want to mess anything up. Take care
Can I cut this wood block out and then just nail it back in?-img_20121005_190113.jpg
amodoko is offline   Reply With Quote
Old 10-12-2012, 07:52 PM   #2
Framing Contractor
That block is a brace for the wall. Reinstalling it can be difficult now that the wall is covered with drywall.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
amodoko (10-12-2012)
Old 10-12-2012, 09:18 PM   #3
Yes, you may have to toe nail it
Rocket98 is offline   Reply With Quote
The Following User Says Thank You to Rocket98 For This Useful Post:
Old 10-12-2012, 09:23 PM   #4
What is it your soldering, that boards a long way from the pipes. Just air the flame down.
Old 10-12-2012, 09:53 PM   #5
DIY Enthusiast
sublime2's Avatar
It appears that it may have been a nailer.
Its not a fire stop. You could cut it out and leave it out.it's not supporting anything.
sublime2 is online now   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
Old 10-12-2012, 10:31 PM   #6
Thanks guys, I think I'm just going to cut a portion of that block out and then nail it back in when I'm done soldering. And to answer joecaption, I'm soldering a frost proof sillcock in (didn't feel like using a shark bite since I've heard mixed things about their reliability over the years) and it is really hard to tell in the photos but it actually is far up in there and between pipes and wood. I actually had a thread on it here with more photos if you're interested:
Help needed with soldering a frost proof sillcock in
It is so tight that I can't fit my benzomatic propane torch in there, the pictures don't show it well though.
If I don't cut the wood block out, I would have to do a roundabout path with more copper and couplings (which is fine too, but I want to avoid that).
Old 10-12-2012, 11:19 PM   #7
Sometimes in tight spaces best to cut back further, cut out section then solder in fitting then solder the whole piece in. This depends on how it is all located.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
Old 10-13-2012, 12:52 AM   #8
Moderator
If not backing for a wall below (holding it plumb, or a drywall ceiling nailer backing) check if the stairs land there. I run the newel post 2x's through the floor and attach to the joists for lateral strength above. If that vertical 2x in the shadow goes through the floor... or the end of a short (1/2) wall.
It's there for a reason.
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
amodoko (10-13-2012)
Old 10-13-2012, 02:40 AM   #9
Hmmm, I don't know if I should cut it then since I don't want to mess anything up. This is in a basement corner actually, and it is also the corner of the house, meaning the outside of the walls there is just my parents' lawn. It looked like the wood block was being used for support, but I hoped the main support was within the walls (shown in the photo to the right where another wood block is sitting on top of it, perpendicular to where the wood block I want to cut runs ). It looked like the part I wanted to cut was safe to cut, but I'm not good at analyzing structure.
I should have taken more photos,but I was hoping that I could just cut it, and then nail it back in and it would be sufficient support. Or maybe even use lag bolts or extra wood blocking for reinforcement.
Hmmmm...
Old 10-13-2012, 01:19 PM   #10
It looks to me that it's a block they used to frame the wall to. If floating walls it might be hung from it. If not and your walls sheathed in drywall you can probably live without it.
tham
Tham is offline   Reply With Quote
The Following 2 Users Say Thank You to Tham For This Useful Post:
amodoko (10-13-2012), sublime2 (10-13-2012)
Old 10-13-2012, 11:17 PM   #11
DIY Enthusiast
sublime2's Avatar
Buy yourself a cats claw.remove the 2 nails holding that piece of wood on the left.
Once removed push the wood up and away.when finished,push wood back in place and put the nials back.not in the same holes though.
amodoko (10-14-2012)
Old 10-14-2012, 04:29 AM   #12
Hey, that's a great idea! I will definitely try that out as soon as I get the chance
Old 10-14-2012, 04:59 AM   #13
An old Tradesmen
Put a piece of sheet metal between the pipe and 2X4 and solder the joint. Or go out and buy a soldering pad.
http://www.emtechinc.net/specpdf/PlumbersPal.pdf
The Following User Says Thank You to beenthere For This Useful Post:
Old 10-14-2012, 07:08 PM   #14
Moderator
If those are engineered I-joists, don't nail (10-16d) through the bottom/top chords as pictured. Toenail (with 8d) any blocking so as not to separate or split the glued lamination of I-joist. The blocking should actually be nailed through the web OSB. Add another above it before you cut and offset keeping the strength. Years ago, I had a field I-joist rep tell us that before and all the literature shows same.
Gary
Old 10-14-2012, 08:55 PM   #15
GBR, thanks so much, adding more support before removing the wood block is such a basic idea but I hadn't even though of it. I will definitely do that. And the other suggestions will be noted as well. Thanks again, much appreciated
