Can I Cut Away These Studs For A Large Chimney Pipe? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-21-2012, 09:22 PM   #1
Rewards Points: 16
Can I cut away these studs for a large chimney pipe?
I just finish putting framing around my fireplace. I was wondering if I would be able to cut away the studs where the pipe is going to go through? There is no attic and it is an add on to the house. The roof is very low almost flat above. Would I run into any danger cutting that away or should I add some support before I cut it or move the piping around?
Thanks for your advice!
Can I cut away these studs for a large chimney pipe?-img_20120821_214718.jpg   Can I cut away these studs for a large chimney pipe?-img_20120821_215000.jpg
guitar548 is offline   Reply With Quote
Old 08-21-2012, 09:32 PM   #2
Rewards Points: 14,312
A low slope or flat roof is hard enough to keep from leaking, and not a good idea to be cutting up the rafters holding up the roof.
Concider going out that wall instead.
Old 08-21-2012, 09:35 PM   #3
http://www.ventingpipe.com/stove-chimney-kits/c15656
Old 08-22-2012, 05:48 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Simple Answer: NO - especially the double.
Install a pipe-connection that will allow you to angle the pipe slightly (offset), then continue straight-up, going through the bay portion, (between) the roof joists.
- Build Well -
The Following 3 Users Say Thank You to AtlanticWBConst. For This Useful Post:
chrisBC (08-23-2012), drtbk4ever (08-23-2012), oh'mike (08-22-2012)
Old 08-22-2012, 07:37 AM   #5
Rewards Points: 150
Good advise^^^^
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 08-23-2012, 09:42 AM   #6
You might be able to use a 15 or 30 degree elbow to offset the piping to get around the stud. Here's a link that might help you, they have good advice and free shipping. What kind of pipe do you have? They have metalbestos Class A.
http://rockfordchimneysupply.com/met...components.php
seger137 is offline   Reply With Quote
Old 08-23-2012, 12:11 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 802
Be sure to read how much clearance you will need around the pipe through roof also.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 08-23-2012, 01:39 PM   #8
AHH, SPANS!!!
Rewards Points: 1,166
nice framing job! I would consider adding/screwing to the two studs next the chimney a stud that turns the opposite direction to the ones you framed and that will give more lateral strength to the wall. Or, to brace the wall -add a stud to the backside of the wall that is horizontal across the entire wall ( like the header you have above the chimney) screwed to each stud to help make the wall stronger. good luck!
hand drive is offline   Reply With Quote
Old 08-24-2012, 07:57 PM   #9
ScottFla40's Avatar
As previously stated, I would offset the riser to clear the studs. Cutting into studs is never a good idea.
ScottFla40 is offline   Reply With Quote
Old 08-25-2012, 07:53 AM   #10
FWIW, To clarify; Those appear to be flat-roof construction - roof "joists", not wall studs.
- Build Well -
Old 08-25-2012, 09:20 PM   #11
Listen to us please don't cut. Good advise here and you chose to use it.
Salute,
Tham
Tham is offline   Reply With Quote
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 12:49 AM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 12:50 PM
Heading off roof rafters for chimney pipe. jrcurto Carpentry 4 10-29-2008 12:25 PM
Heading off roof rafters for chimney pipe. jrcurto Roofing/Siding 1 10-28-2008 04:25 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
