Can I Connect A Modular Home To My Existing Stick Built Home? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-02-2013, 09:30 PM   #1
Can I connect a modular home to my existing stick built home?
Needing to add on to our current 1300 sq. ft. home......what is the best option? We need to add at least 2 bedrooms and a bathroom. What is better? Building up, out or can I bring in a used modular home and add it to our existing structure? What would be most cost effective and give the most added square footage? Any suggestions would be appreciated.
mememe is offline   Reply With Quote
Old 01-02-2013, 09:52 PM   #2
Rewards Points: 150
You can attach a modular home to an existing stick frame building as a modular is tpically specifically built for your needs, but you mentioned used. I have to wonder where you would get a used modular section and if it will mate up to the existing. Whether new or used check with your local Building Dept. and see what standards the modular must meet, energy efficiency, seismic, high wind, etc., and then start contacting some modular companies that are approved in your jurisdiction and contact some local contractors and see what is most cost effective for what you get. Whether it is readily achievable to go up and the cost comparison to a first floor addition really depends on what you have now. On some older homes it is a lot of work to go up, e.g. sistering joists, new first floor framing to support the second floor load, basement columns, high wind strapping on the existing structure,etc., and if you are installing a stair it can take up space where you lose a room on the first floor. The above is long winded because of the variables. I suggest you see a design professional, e.g. registered architect or professional engineer for specific guidance. Good Luck.
TheCamper is offline   Reply With Quote
Old 01-02-2013, 09:57 PM   #3
Rewards Points: 13,266
It would be far cheaper to just buy a larger home.
If you decide to go up you can not stay in the home until at least the second story is built and dryed.
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 05:49 PM
new porch roof to existing home jscholl411 Roofing/Siding 6 10-12-2007 12:24 AM
Installing 'peal and stick' vinyl squares on top of existing .... alexz Flooring 8 02-17-2007 05:20 PM
cost of trusses vs stick built ugabulldog Building & Construction 2 10-17-2006 11:15 PM
modular home flooring problem wen Flooring 1 08-15-2005 02:11 PM
