Can I Attach A Top Plate To The Central Beam Of The House? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-05-2009, 07:34 PM   #1
Rewards Points: 174
Can I attach a top plate to the central beam of the house?
I have a 5.5 x 7.5 beam that runs the length of the house in the basement. I was wondering if I could use the beam to frame a wall from underneath it? I was originally going to frame the wall using the joists that run perpendicular to the beam directly in front of it. I then realized that I would get a few extra inches of space if I started under the beam.
Being that I am using 2x4's I would have to create a sofit like effect with the sheetrock on the other side of the wall.
Leoskee is offline   Reply With Quote
Old 08-05-2009, 08:26 PM   #2
Rewards Points: 162
I see no reason not to attach the top plate of your new wall to the bottom of the beam. The only thing I would watch would be cutting your studs to the exact right length or a hair shorter. If you try to pound studs in that are a hair too long, it will transfer load off the beam to your new wall.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 08-05-2009, 09:19 PM   #3
Rewards Points: 174
That makes sense. So then, what would be the margin allowed for the length of a stud to be "just right" to be nailed in?
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Help: No place to attach top plate AlSmith Carpentry 3 05-21-2009 04:31 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Ridge vent leaking? Or what? Whatever1 Roofing/Siding 10 09-25-2008 06:24 PM
