Can GRKFasteners Be Used In Decking For Concrete Fastening? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 11:42 PM   #1
Rewards Points: 43
Can GRKFasteners be used in decking for concrete fastening?
I saw these the other day in Lowes, look brand new. They are something called GRKFasteners and are concrete screws for outdoor use (climatek coating - whatever that is).
Curious if this can be used with pressure treated wood and for securing to concrete?
Are there any existing concrete screws out in market today rated for outdoor use and for PT wood?
Quicksmoke is offline   Reply With Quote
Old 04-18-2012, 12:11 AM   #2
Rewards Points: 12,842
If it does not say ACQ approved on the box do not use them.
There also going to have to be case hardened to work in concrete.
#1 other then a bottom plate in a wall no pressure treated wood should be used inside a house.
#2 If you thinking of attaching this plywood to a concrete slab floor to be used as a subfloor not a great idea. For several reasons.
Old 04-18-2012, 12:14 AM   #3
DIY Enthusiast
sublime2's Avatar
Yes they can....
sublime2 is offline   Reply With Quote
is the decking over foundation considered structure sn604s Building & Construction 4 01-21-2012 06:02 PM
Trex decking LL1 General DIY Discussions 56 09-30-2011 10:55 PM
Fastening ends of porch decking w/out compromising flashing danf26 Building & Construction 1 09-08-2011 06:58 PM
Survey on Trex composite decking TC1 Carpentry 22 04-13-2010 02:21 PM
Trex Decking over Treated Decking retired2pa General DIY Discussions 6 12-15-2009 07:16 PM
