Can Foil Faced Foamboard Insulation Be Layered? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-11-2009, 02:47 AM   #1
Can foil faced foamboard insulation be layered?
Dow Corning Super TUFF-R Polyisocyanurate insulation board is faced on both sides.
1 side is blue (don't know what the blue backing is called)
The other side is foil faced (Aluminum foil I believe)
If I get the 1 inch board, can I layer 4 layers, one on top of another?
Reason I ask is because of the foil backing. The foil backing acts as a vapor barrier so would layering these boards trap moisture in the foam and between the multiple boards , not allowing moisture to escape?
BTW
Is this in the right sub forum or should it have gone in the General Forum.
Spud is offline   Reply With Quote
Old 10-11-2009, 07:38 AM   #2
I don't think that is the right way to do it. You have two vapor barriers, which could trap moisture between them.
Old 10-11-2009, 06:48 PM   #3
Dow has insulation boards that have foil facing on both sides, so that would trap moisture in the sandwiched foam?
As far as trapping moisture goes, would these double foil facing boards be similar in effect to layering multiple boards with single sided foil facing?
Or would the problem for me be the space between boards trapping moisture? and this wouldn't be an issue for single boards with double sided foil facing.
Dow Corning Tuff-R has foil facing on both sides.
http://building.dow.com/na/en/produc...tion/tuffr.htm
Versatile TUFF-Rô Insulation fits numerous residential insulation and sheathing requirements and can be applied to a variety of substrates. It features a high-performance polyisocyanurate foam core with radiant barrier-quality aluminum foil facers on both sides (one side reinforced).
Old 10-11-2009, 08:17 PM   #4
Civil Engineer
Rewards Points: 4,578
The standard reasons given to avoid trapping moisture in insulation is to :
1. Avoid damage to the insulation due to moisture (some types of insulation, like cellulose, are adversely affected by moisture)
2. Avoid reduction in insulation R value
3. Avoid damage to adjacent wood surfaces due to condensed moisture
I don't see trapping moisture inside the polyisocyanate as being much of a problem, since the material is not susceptible to moisture damage, the R value is only going to be minimally affected by moisture, and if the moisture stays between the foil barriers, you care not going to affect adjacent wood surfaces. If the system traps moisture against a wood surface, that is a different problem.
Daniel Holzman is online now   Reply With Quote
Old 10-11-2009, 08:27 PM   #5
Will moisture migrate to the sides where it will come into contact with the rafters?
The ideal solution would be to just buy 4 inch thick Polyiso foamboard but I am not aware of anyone who makes such a thing.
I see that residential Super Tuff-R max thickness available is 1" but Super Tuff-R Commerical comes in max thickness of 2". Why is 1" the max available for residential?
1" of residential Super Tuff-R residential has an R-Value of 6.5.
The 2" Commerical Super Tuff-R board is R-12, shouldn't it be R-13?
why the slight loss in R-Value?
Commerical Tuff-R 2" is R-13.
Why does commercial 2" Tuff-R have R-13 while commerical Super Tuff-R has R-12?
Old 10-12-2009, 08:27 AM   #6
Rewards Points: 109
I emailed Dow several months ago about stacking 2" boards and they said that it was OK.
BimmerRacer is offline   Reply With Quote
Old 10-12-2009, 11:43 AM   #7
Rewards Points: 346
I am pretty certain it's not the foil giving the foam it's ability to stop vapor penetration. The foam itself is the closed cell type so this would be a vapor barrier even if the foil was not there. The foil is heat reflective and you would want this facing or the side where you want to keep the heat. Heat energy is somewhat like light when it comes to reflectivity, hence the reason for the foil. I can see no reason not to stack it as long as you could stacked it tightly. Alternating the foil facing sides should make it more effective, two facing in and two facing out. Staggering and taping the seams of each layer would also make it more effective than just stacking it.
Rege
RegeSullivan is offline   Reply With Quote
Old 10-12-2009, 10:04 PM   #8
Rewards Points: 95
Why not just buy some foam that has no foil face and just have your last layer with a foil face?
NJ Brickie is offline   Reply With Quote
Old 10-12-2009, 10:30 PM   #9
Haven't found any that has R-6.5 per inch or higher. The non faced foam (blue foam) has only R-5 per inch.
If I could find a foil faced foam baord that is 4 inches thick, or non faced foamboard that is R-6.5 or higher per inch.
Old 09-30-2010, 07:37 PM   #10
Hisi
There are several manufacturers of high density EPS foam - (compressive strength of 35psi plus that have R5 per inch ).
Amvic Building System in Toronto Canada makes up to a 5" thick board foil face 2 sides that has an R factor of 25.
Not sure if this is available in the US or not yet .
HC
HISI is offline   Reply With Quote
Old 09-30-2010, 07:41 PM   #11
Tom Struble's Avatar
Rewards Points: 2,002
if its a vapor barrier,hows the vapor going to get inbetween? i would offset the seams then tape them,like dow says it's ok
Tom Struble is offline   Reply With Quote
Insulation - Faced vs. Unfaced + Plastic Sheet WaldenL Building & Construction 4 07-06-2011 12:41 PM
Faced or Unfaced Insulation in Attic??? capenpeck Building & Construction 13 11-06-2009 08:23 AM
Can foamboard insulation be used in living areas, vaulted ceiling? Spud Building & Construction 14 10-13-2009 01:48 AM
19" spaced joists - foil faced insulation? CWorth Remodeling 3 03-21-2009 01:26 PM
Using rigid foil faced foam insulation Ronnie1a Remodeling 1 01-22-2008 02:23 PM
