Can Exposed Aggregate Concrete Be Cut... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 04:39 PM   #1
Rewards Points: 77
can exposed aggregate concrete be cut...
...without trashing it? I have a sidewalk leading up to my house with a small pad connected to part of it. I'd like to cut off the pad, leaving the sidewalk only. It'd be about a ten foot cut.
Thanks for any suggestions
dbldee20 is offline   Reply With Quote
Old 12-08-2011, 04:45 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Go for it. You can use a circular saw with an abrasive masonry blade but using a wet-diamond blade would give you a cleaner and faster cut. Just run a little water on the cut as you proceed. Don't get in a hurry and don't scorch the blade if you use a diamond blade.
The Following 2 Users Say Thank You to Bud Cline For This Useful Post:
concretemasonry (12-08-2011), woodworkbykirk (12-08-2011)
Old 12-08-2011, 06:28 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,... I completely agree, Except,...
For a 10 foot cut, I'd go rent a walk-behind roadsaw...
With a 14" diamond blade, 'n water runnin',...
You can follow a line for a really straight cut....
A handheld gas demosaw would work too,...
It's just harder to get a straight cut, that Long...
With a 7, 1/4" circular saw, you'd be Days cuttin' a 3" slab, 10 Feet...
Old 12-08-2011, 06:44 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
It is not very often I disagree with Bondo, but there is a very nice little rail and water rig you can clamp to the Skill-saw and I get great results in little time.
I can't remember the brand name but it has a wheeled plate that you clamp to the Skill-saw and an attachment for a hose that will spit the water onto the blade as you cut.
It also comes with a GFI gizmo.
It's great and I think only about $40.00.
I will look online for it.
Andy.
AndyGump is offline   Reply With Quote
Old 12-08-2011, 09:34 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yow well at least an hour anyway.
Old 12-09-2011, 08:40 AM   #6
Rewards Points: 77
thanks guys. I was worried about the blade not cutting thru pebbles cleanly and leaving a ripped up or jagged edge.
Old 12-09-2011, 09:56 AM   #7
robertcdf's Avatar
I would bet about 30 mins, we cut out squares in slabs all the time for piers, a 12"x12" (4 LF) takes about 10 minutes.
robertcdf is offline   Reply With Quote
Old 12-09-2011, 11:44 AM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Some of the stones will break, some will cut, some will be spit out of the path of the blade. All and all it can be cut nicely but the resulting edge won't be pristine and sharp enough to skin a deer, it will still just be cut concrete when it's all said and done.
Old 12-09-2011, 01:57 PM   #9
Concrete & Masonry
Rewards Points: 526
You guys must have some huge circular saws if you can cut through a 3-5" thick concrete slab with one.................
jomama45 is offline   Reply With Quote
Old 12-09-2011, 02:16 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You don't have to cut all the way through it and you know that. What, are you just trying to pick a fight?
Old 12-10-2011, 08:23 AM   #11
Concrete & Masonry
Rewards Points: 526
I know that the safest way to remove the slab is to cut all the way through the slab, not to mention that if there's any steel in the slabs, it will be in the bottom half anyways.
garden shed on existing concrete pad hartkem Building & Construction 6 10-27-2011 09:46 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 01:06 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 07:11 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
