Can Deck Posts Be Fixed To Existing Rock? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 10:05 AM   #1
Can Deck Posts be fixed to existing rock?
Hopefully, someone can give me some advice on this...
I am attempting to put a wooden Pergola over a portion of my existing deck. The header board will be attached to the house, and the posts would go into the ground just past the existing deck rail. Here is my problem:
My yard is build on an incline that has rock/granite just below the surface. I am unable to dig 36" as I hit live rock within 10". My building department suggests I drill into the existing rock 6" and put in (2) 1.5" Rhee-Bar posts, then pour 8" concrete over the Rhee-Bar. Finally, I should bold braces into the concrete footing and affix the posts to these braces. This seems a bit much to me for a non-weight-bearing structure (Pergola roof).
My question (long-winded) is as follows. Would it not be possible to bolt the posts directly into the existing rock/granite (pretty sturdy I would think), and if so, what type of bolt process would be required?
Any suggestions or insight is deeply appreciated. I feel as if the local building department is giving me the run-around and being a bit excessive.
Ken
drcieslak is offline   Reply With Quote
Old 08-03-2011, 10:45 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
If you will require an inspection, you might be better off just doing what they want!
With that being said, you could use stainless wedge or sleeve anchosr to connect your mounting sleeves to the stone easily. You could also use an epoxy and stainless rod system. I would run any plans past them first. No point in incurring the expense and effort to do in a way that they won't approve anyway
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-03-2011, 04:14 PM   #3
Rewards Points: 5,336
Make your suggestions to the building inpector, but as Mr Chips said, they decide what's going to be done if you want to pass inspection.
Ron
B. Franklin 1759
Old 08-03-2011, 04:35 PM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
I would dig down to the rock and drill and install a few re-bar as stated. build a cement forum and pour a footing pad on top of the rock. then fasten your girder on top of the pad with the proper fastener. just a thought. I am thinking that this rock is of some great size.
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Framing deck using 6x6 posts supporting pavillion above bassprokd Carpentry 3 04-27-2011 06:28 AM
Extend existing deck dknarnd Building & Construction 1 04-25-2010 08:09 AM
Deck Guard posts on top of deck posts -how? davis_mc Carpentry 1 04-18-2010 07:42 PM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 07:03 PM
