Can 2x4's Support 5/8 Sheetrock? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-30-2006, 03:05 PM   #1
can 2x4's support 5/8 sheetrock?
hello,
in my existing garage , i plan to wire, insulate and shhet rock. the roof or "ceiling", is built with2x4's. it makes me alittle nervous to put up 5/8 sheetrock up there. will it support it? are there any other light wieght materails that anyone knows of that can be used instead? that are not ugly.any suggestions are welcome, even if they seem odd. like how about that fake tin plastic stuff?that might look stupid on a pitched ceiling, though? thanks
jude is offline   Reply With Quote
Old 11-30-2006, 03:32 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Is the roof stick framed or do you have manufactured trusses?
What is the spacing of the trusses/framing? - 16", 24", ??"
concretemasonry is online now   Reply With Quote
Old 11-30-2006, 03:39 PM   #3
just went to measure...
stick and 16.
Old 11-30-2006, 07:25 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Run some long 2x4x16's perpendicularly across the top of the ceiling joists and attach to the joists (To spread the support of the 'new ceiling' among all the joists)
Then attach some 2x4's vertically. Do this near the centers of the joists (Dependant on the span)...attach from the ceiling joists up to the rafters to support the area.'
Make sure that you have the joists strapped as well 16 O.C....
...Simple and effective.
- Build Well -
How much load can a 20' long 2x8 support? GrdLock Building & Construction 9 06-29-2007 12:15 PM
where to get support beams elementx440 Building & Construction 5 03-21-2007 06:19 PM
Reparing sheetrock abelsu Painting 8 02-23-2007 10:41 AM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 09:55 AM
