Can 1 Chick Demo A Sidewalk With Sledgehammer - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-09-2008, 06:33 AM   #16
Well as long as we a betting beer.
I'll give the following odds:
4:1 No rebar
2:1 No wire mesh
FOB: Jacksonville, FL
Big Bob is offline   Reply With Quote
Old 10-09-2008, 07:25 AM   #17
bofusmosby's Avatar
Naw, I bet there's no rebar, or wire mesh. How does one mail a beer????
bofusmosby is offline   Reply With Quote
Old 10-09-2008, 07:57 AM   #18
the Musigician
DangerMouse's Avatar
seems odd to me that in the safety conscious atmosphere here that only micromind mentioned the use of safety glasses.
hammer+concrete=100mph+ debris.
DM
Old 10-09-2008, 10:35 AM   #19
bofusmosby's Avatar
Now thats a little unfair. When I was reading the thread, I was going to mention that when I made my post, but someone beat me to it
Old 10-09-2008, 09:02 PM   #20
Knucklez's Avatar
Rewards Points: 942
ya, i did a lot of jack hammering last month for the first time in my life. what i learned (the hard way) was repeated by the good posts above.
let me reiterate some tips (hopefully there's a new one for you)
- do yourself a favour and rent an electric jack hammer. it comes with 2 types of bits usually, a dart shapped one and a flat head shapped (not sure which is best for your project).
- ask tool rental company to demonstrate how to change the bits, it is a bit tricky to learn otherwise!
- the jack hammer is HEAVY when not in operation. i was using it on a stone portch and the tip of it slipped off the edge and nearlly took me with it!!
- if the jack hammer falls over, or falls just LET IT GO.. its built tough, it can handle it (your back can not).
- when the jack hammer is in motion, it sort of glides on the surface as if it ways very little
- when you STOP hammering, be aware that the machine will "suddenly" gain 100lbs... so make sure it is standing perfectly upright before you turn it off
- get a 6' iron pry bar.. this helps a LOT! you can rent them from home depot (i had one handy and couldn't have removed my stone porch without it).
if you are jack hammering a particularily thick piece, like more than 12", then it is usually a good idea to undermine the stone. i.e. chip away its belly or side to create a cavity, and then put jack hammer directly on top and go straight down.
make sure you pull the jack hammer out a bit.. or the spade will get stuck in the stone/cement. like, if you are hammering down straight and you can't see the tip of the blade anymore, give a pull straight up and then let it drop back into the hole and keep going. if you can pull it out like this, then it is not stuck. the deeper you go, the more you risk the jack hammer gets stuck in the cement, very hard to get out!
waste disposal for concrete is fairly cheap (it is recycled as "clean fill"). find a dedicated place for stone/concrete and you're looking at $30 per tonne... otherwise you dispose of it at the city landfil and it will cost you easly twice as much.
wear safety glasses! flying concrete chips go everwhere.
wear safety shoes - you'll eventually try to jack hammer your toes, trust me
post some pics of your project & good luck
Knucklez
Knucklez is offline   Reply With Quote
Old 10-10-2008, 06:41 AM   #21
the Musigician
Knucklez
wow, i've heard of "hammer-toed" but...... lol
ya know, she's probly all done and forgot us here.... never get to see all our pithy responses. =o/
DM
Old 10-10-2008, 12:54 PM   #22
Drywall contractor
Rewards Points: 1,070
The easy way to do it from what I've read is to use an "expansive cracking agent" such as Bristar or Dexpan. Chemicals are mixed with water and poured into 1-1/2" - 2" holes drilled with a rotary hammer. Over 24 hrs. the stuff expands with about 18,000 lb.per sq. in. of force and turns the slab into pieces you can handle. If the slab is connected to the house, you have to be careful not to break your foundation though. I'm guessing all this, with renting a rotary hammer and buying the chemical, would be more than the $100 quote (no idea what the chemical costs, but I'm guessing not cheap). I'd sure like to see it done some day though. Best of luck however you go about it!
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-10-2008, 04:58 PM   #23
I worked with bristar, maybe 15yrs ago, great stuff, as long as you know how to mix it. I'm still voting for the electric hammer, although I know full well that air hammer would do quite nicely. Slamming that sledge down on the concrete is going to be like someone already mentioned, pounding the soil under it. If going with the hammer, be better to use a chisel with it, get the full effect. As for disposal, as someone mentioned, I paid $84 a ton at the local landfill/transfer station, next town over, clean rubble was at $40 a ton, I used local to save time and fuel, mostly the time was needed. This will turn into one of those times where we can all pull up a chair and watch the show.
DUDE! is offline   Reply With Quote
Old 10-10-2008, 06:01 PM   #24
Drywall contractor
Yeah, I mentioned the expanding stuff kind of "tongue in cheek"...... sounds neat, but I'm sure in the wrong hands (mine perhaps) it could be a clusterbang! I'd like to see it work some time though.
Old 10-23-2008, 12:08 AM   #25
pry it up make it hollow under place a wedge smack it to crack it place braker pry bar in crack and lift smack it crack it and yes it is not hard to break if you do not have wire in the mix
often is offline   Reply With Quote
Old 10-23-2008, 03:28 AM   #26
now we know wire's REAL purpose - to hold cracked pieces of conc together
yesitsconcrete is offline   Reply With Quote
Doing demo - plumbing coming through floor pcampbell Plumbing 12 09-28-2011 10:25 AM
Pavers over a concrete sidewalk Beckerad Flooring 3 07-20-2010 08:59 PM
Sidewalk Edger jwsmas Landscaping & Lawn Care 4 09-03-2008 10:34 PM
Sidewalk drainage issue! Bcoleman6 Building & Construction 1 07-07-2008 02:17 PM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-24-2005 11:40 PM
